Need help with new system going kinda big
Not to sound like a dick, but with your kind of budget that kind of system wont happen, the amp or amps will cost you 900+ unless you want to go the cheap way, batts will be no less than 600+ unless you buy cheap batts or used, a h/o alt 400+, subs to handle 6k 300+ each sub, sound deadener, mids and highs upgrades, multiple runs of zero gauge, possibly custom door pods,materials for box building, imo bring your budget up to 4k+ or step down to maybe 3k-4k in power.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
alright what will uall suggest i already have 4 sa 12's and a powerbass xa3000d should keep it or add to it? like more power or more subs?
Are you not happy with the output from the above setup? Throwing a bunch of power at the problem isn't always necessary. You could try a more efficient design like bandpass or ported at a different freq. to get more out of what you already have. What are your goals? Is walling an option? What kind of music do you prefer? Are you comfortable fabricating pods for the doors or kicks? How much are you willing to spend on your frontstage? Do you want a daily monster over 150db? These are just a couple of the questions you need to ask yourself.
Most of us have gone through several setups trying to build a future-proof system. Stick to a budget if you must but not at the expense of what you want.Take your time and do some research and scour the net for deals. If it takes a year to get everything you want; fuck it, that's how long it takes. hahahaha
In the end it all comes down to how far you are willing to go to get what you want. I have spent ~2k and my setup does 145's on music (1500 watts) which I think is great. It's certainly possible to get loud-ish lol on low power with inexpensive components...but it will take some research like I mentioned. Once you get a handle on what you really want out of your system you'll be much happier and building it should be easier.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
4 aq hdc3 15's = $1116
2 aq 2200's = $858
2 deka 9a31's = $474
1 deka 9a78 = $156
100' of 1/0 = $200 - $350 range
Alternator =$350 minimum
Wood for box =$200 minimum
total $3354. Those are just some good bang for your buck products with easily accessable prices. the brands you choose may cost more or less. Browse the forums to see what people think about different brands, shop around, SEARCH FUNCTION.
Edit: DOES NOT include shipping where applicable
Edited by Sanitarium
Ima go with what remt15 said and add 2 more sa 12's i was thinking doing a 4th order but whats the difference between a 6th order and a 4th order? and my electrical consists of a optima yellowtop up front and a xs power d3400 in the back and stock alt for now but going to order a singer 350a alt next week. i would need help on a good box design. as far as my goals, try to hit as close to a 150 as possible but thats if i can right.
6th order is usually louder than a 4th. i've designed both.
6th is ported into ported
4th is sealed into ported
Edited by 412 CVX
More box builds
I'm with captain stupid.
  • Who's Online   1 Member, 0 Anonymous, 1401 Guests (See full list)
