Well the past 2-3 nights ive been working on putting my sub that fell apart back together and last night i got it finished.
this morning i went to do a video of it to show that it is indeed working. well i put it in its box and plugged it into my little 100w radio and it started playing but it was making a weird noise and it was playing VERY little bass. i started poking around on it and anywhere except one section it cuts out all bass BUT when i push on one section it plays perfectly....does anyone have any ideas or knowledge or anything that could help me out? im afraid to put it back in the blazer cuz with it acting like this im afraid itll blow the coil when i hook it back up to my amp.....
Edited by Junior Russell
http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187
JVC KD-R530 head unit
VVME INNO-D1500 sub amp
Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms
DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared :( )
not as far as i can tell ive checked it all around and it doesnt seem to be
That's my guess. Coil isn't aligned properly, so when you push that "sweet spot", it sounds normal. Anywhere else you push, it grounds out.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
hmmm well damn its going to be a bitch to get it back apart to where i can put it back on with it aligned....btw how would i go about aligning the coil?i tried the paper trick and theres enough room where the coil doesnt touch the inside magnet but not enough room to wheree i can get a peice of paper of something in there to make sure its spced properly...
You have to get a whole new recone. I've never heard of someone able to take off the soft parts to realign them.
this is the second time ive done it the first time the paper cone tore off i put it back on and decided to just switch out the cone and add another spider for stiffness and it worked up til bout the begining of this month and it over heated and detached everything so i decided to repair the original paper cone and put it all back together....dont beleive me check the vids ive got on youtube...
my first guess is tensil leads. second guess coil rub.
well the leads are out of the way and arent moving from their spot as for the coil rubbing i have no way to see inside to see if it is or not but thats what everyone seems to be thinking it is so im probably going to end up taking it back apart and aligning it again then gluing it again....
Edit~ also forgot this but i took it out of the box about 5 mins ago and it plays perfectly if you push on the corrisponding section of the spider also the spider is extremely stiff
yeah it was coil rub thank you for your help in pointing me in the right direction
yall should check out the description
sounds horrible imo....not to be a dick but something isnt right at all. and do you have trailer lights hooked directly to the amp?..... that sounds like a bad idea as well lol
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
  • Who's Online   0 Members, 0 Anonymous, 2079 Guests (See full list)
