Could be the Voltmeter just showing the wrong readings, do you have a multi meter to check it?
I may have to redo my voltmeter, and borrow a DMM from someone, my AMM isn't going to read it well.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
I got a buddy who has a Stinger but its on a bad ground on the dash so whenever the dash flexes the voltmeter drops into the high 10's when he really stays above 13 so that could be the problem
1898070_635754349830843_1457278514_n_zps
Yeah, when I play into the 20's, or low 30's, I see 10's as well, think the vibration is messing with it due to poor connection.
2003 Kia Sorento
Team Subsonic Lows
If that's the problem it can be a quick fix luckily
Well, I'm gonna confirm the problem when I get my hands on digital multimeter
2003 Kia Sorento
Team Subsonic Lows
If this fix would not affect, then is it time to upgrade your 4 gauge from battery to the amp...?
Volvo S70 - 150.8dB @ 46hz from the trunk of the sedan with 3.5kW
I don't think upgrading my power wire will fix my voltage drops, plus let me fix my voltmeter issue first, and then see.
2003 Kia Sorento
Team Subsonic Lows
So I decided to reinstall my voltmeter, cause I half assed on the last install
Using parts from the dashboard
Heat shrink
heat shrinked
soldered connections
strong connection
Wiring mockup
switch holder
Mockup
Place of installation
installed
hooked up directly to amp
resting decently
And my electrical still sucks :(
http://youtu.be/zi2HqvwUTsI
2003 Kia Sorento
Team Subsonic Lows
Like the placing of the meter. Have you shot this by Snafu? I have no clue as what to next as you have went through almost everything. As long you don't need a better ground location. This sucks don't it. Even with the stock alt it should handle better than that IMO. How long do you think it will be for the alt rebuild?
If I find a job, it shouldn't take long
I'm thinking about using the alt you gave me to see if I see better results, according to my question, the guys concluded that my alt is going bad.
By the way, how old is the alt you gave me, and how long has it been used?
2003 Kia Sorento
Team Subsonic Lows
