ya i am doing an install on the 27 of this month and will be using that same exact kit if you look on there web sit they have a few different kits and with different size wire
alright thanks man.
why would u put 0gauge on that its overkill :huh:
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
better to go bigger than smaller. in that application 4 gauge is fine. but i will always always use the biggest wire i can. overkill or not. then if i wanna upgrade, i already have the biggest wire i need
that amp is only around 800 or 900 rms, why go throught the hassle of putting 1/0 gauge on it when it only requires 4ga ........... now if you have more than one than yeh use 0 gauge but run ito to a dist block and run 4ga from that to the amp(s).
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
"why would u put 0gauge on that its overkill"
No, it is not an overkill. There is considerably less resistence by using 0 gauge wiring since you are giving the electricity that is flowing through the wiring more space. 4 gauge wire has more resistence because you are trying to pull the same amount of amperage but just in a smaller space. It is actually better for the amplifier to do it this way.
I am doing the same thing with my crunch Pzi 3000 . The amp has 4 gauge fittings but I am using reducers. However, I did have to shave down the reducers to get them to fit in.
Edited by cichlidfort
2008 Chevy Impala (undercover cop style)
Setup in the makings
that true if you have a good amp :lol:
MLA module 15+volts
Team Bass Hz
why use 1/0? the amp obvisouly isnt designed for it, so do it right and buy a distrobution block and call it done.
X2
