Noticed I had a miss at idle..changed plugs and it went away then came back..now its gone..but under full throttle underload it will stumble like a miss and sounds like a mini backfire through the intake... I'm think fuel injector an I read maybe fuel pressure reg... then I second gues an think its ignition..any help is appreciated..need this fixed I'm afraid its goin to get worse...
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
How olds your fuel pump
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Do you know if this has the "spider leg" type of fuel injection on it?
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
Have you changed plug wires?
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
Fuel pump is at least 4yrs maybe more I haven't changed it ill ask my friend I bought it from..yes it has the shitty 2 piece manifold with the spiders n poppet valves..I dumped some seafoam in a full tank of gas today..it runs good during normal driving but sputters full throttle for a brief second when hard shifting etc...haven't changed wires...my hoe is considered my work truck and its my daily driver..my boss said throw it in the shop on Monday... :-)
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Mine did something similar right before the fuel pump died
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Thanks n8...that mite be the issue...I'm thinkn since jumping to 14v its been hard on my electrical..fuel pump , ecu, tranny ..all weren't designed to run mid 16v...
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Pump or spider injectors had almost same shit with mine went threw a ton of different thigs trying to figure out what it was and the seal on the spider injectors and one of the injectors were causing a misfire due to the extra fuel being dumped mine did it more at idel and smoothed out once you got going. Cost me under 500 for parta and labor.
Good luck man
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
Good luck man
I fucking hate spider injection.... Shit was a joke for real.... They should have just used the MPI setup or shit, stick with TBI
Slight leak in the upper intake gasket can cause this, its a known failure on those style motors.. Good luck man
  • Who's Online   0 Members, 0 Anonymous, 1355 Guests (See full list)
