Do you have any diagnostic data? Vacuum readings, fuel pressure, pulse width when this happens?
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
No data.. that's why I'm taking it to mechanic that has the tools an knowledge... I have my old motor in storage it lost a cylinder last dec..an I got this one used..so mite just swap intakes...we will see what mechanic says...I hate intermitent issues..hard to diagnose...thanks guys
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
armykyle1 is probably right. Upper intake gasket. I gotta change mine so I am adding a Vmaxx spacer when I do it. And yes changing the stock poppets out for the better stock spider injectors is a good idea if you already gonna have stuff pulled apart.
Fuel filter
Plug Wires
Air Filter
Start with those 3. Did you gap the new plugs too?
Possibly a coil pack.
Due to the fact that you drive it daily, I'm less inclined to think its a clogged injector than something else. If it was a vaccum leak, you'd more than likely notice abnormal engine temperatures... In an extreme condition.... Intake.
Edited by Blackedout
yes i used platnum plugs gapped at.60..i think its intake or fuel pump..i heard of fuel pressure reg going out also.. who knows about the marine intake? id like to run that if intake is bad..is it smog legal here in cali
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
The Marine intake conversion can be done, if you know what your doing it looks to be a weekend job. I have been thinking about doing the same conversion. I believe even on a 98 you have swap your PCM "0411"(a step I have already done). You can get more out of the motor due to higher air volume and the ability to go to bigger injectors.
http://www.pacificp.com/forum/viewtopic.php?t=317&postdays=0&postorder=asc&start=0
  • Who's Online   0 Members, 0 Anonymous, 825 Guests (See full list)
