Orion Hcca
BINGO...!
HCCA225 to be exact.
One of the classic Cheater Amps from the late 80's/early 90's.
Hey look it has a brother. :drink40:
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
While getting my tilting amp rack closer to being finished, I realized that my fuse panel wasn't quite fitting right.
There was a comment about making it out of plastic/acrylic to help with the insulation since wood is susceptible to moisture.
I ordered some 1/4" thick black acrylic for a trim piece around my sub baffle and added some area to make a new fuse panel as well.
HINT: If you cut plastic with a circular saw, be careful. The shredded bits flying off the blade sting quite a bit more than MDF dust.... :o
I made a cardboard template and got the shape just right and then cut it out of the plastic.
Here are the buss bars laid out.
I used my Forstner bits and drilled some holes for the bolt-heads to fit through.
Do I wish I would have bought a tap and die set for the buss bars so that I don't have to bolt the buss bar from the rear..............yeah, but what's done is done.
This works but it does take a little more prep work to complete.
Here are all the pieces assembled.
Check out what happens when I pull off the paper backing.
..........SHINY
Here's the test fit in the car.
I found a gate latch that should work to secure the top of the tilting amp rack. It needed some grinding though.
Amp rack test fit with the gate latch.
Test fit in the car
Amp rack tilting with a close up of the latch.
Remember when I said I bought a VM-1 and that it wouldn't fit on my dash.....? :ninja:
The VM-1 is square and too high to fit anywhere in my dash cleanly.
Guess what does fit...? Bar-graph LEDs. ;)
So I did a little prototype test with a couple of bar-graph LEDs and a bare PCB board.
First off, I had to remove all the stock LED's. These things are tiny!
All removed.
Started to solder some lead wires from the VM-1 to my proto board.
Proto board soldered.
VM-1 wired up.
Here's what the whole thing looks like.
326VM-1andprotoboardwired_zpsd8cf466c.jp
Works pretty slick although its a bummer I couldn't find any multicolor bar-graph LEDs that include blue.....so I'm stuck with green and red, possibly orange if I light up both LEDs in each segment.
Since the bar-graph LEDs are fairly small, I most likely won't be able to have the voltage printed out next to each LED (maybe every other one) so that is where the VM-1 is nice.
I'm brainstorming a few other ideas for this location in my dash so we'll see how this plays out.
:good:
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
GOD DAMN!! Jamie stop it, stop it right now. You're gonna make the rest of us look bad and that's just not right! DAMN YOU!! Nice job on the fuse panel. That black acrylic gives me a great idea on my own little wiring project! Can you link me to where you got it? Or did you get it local? I have a tap plastics near me, but they're usually expensive.
Nice job, love the moded heater core vent/door nice and clean. I have to admit at first I was like "Oh no, he just cut that off, thats not good" but then a few pics later I was not so worried for you. LOL Great job man!
UBL (Uninterrupted Build Log) - CLICK HERE
# Deck: KDC-BT555U #
# Amp - Mids/High: PPI MOS-50 #
# Amp - Subs: Hifonics 1100.1D #
# Wire: 4awg 120Amp Fuse #
# F - Mid/High: RE Audio RE6.5C #
# R - Mid/High: RE Audio RE5x7FR #
# Subs: 2x12" Kicker CVR #
:blush: ...whatever
Just trying to come up with some unique ideas and keep everything clean. ;)
Yeah, the black acrylic came out a lot fancier then I was expecting.
I was just looking for some dull black plastic to mount the buss bars too and when I pulled off the paper.........
I've gotten most of my plastic parts from
http://www.estreetplastics.com/
Good variety of stuff and the prices aren't that bad.
Shipping is quick too.
Thx! :drinks:
Yeah the dreaded double-DIN install is not for the faint of heart. iw as not excited abut hacking into my vents but it needed to be done.
:D
Clever... really clever...
Always good poop man.... Dig it... ;)
:poop:
:drink40:
Thanks to the other SMDer's for the great posts on the actuator. Can't wait to get the switch permanently placed in the dash so I can start putting it to work.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
