More sanding :detail:
Giving the port extension a test fit:
Some close ups. The tapered contour is starting to come together:
The inside of the port extension will need some paint and not just some regular rattle-can black.
I picked up a can of charcoal-like paint a while back for the work I did on my ashtray area that should match the interior nicely.
Rather then having to sand down a bunch of brush marks, I figured that spraying it would be the best option.
My air brush is a bit too small for that job so......another trip to Lowes :D
This should do nicely and also work for spraying out larger quantities of contact adhesive as well.
I rebuilt the port piece that fits into my rear deck, it needed to be widened out a bit to give a better round-over edge.
Just needs some body filler to smooth it out, but first I need to secure it to the rear deck lid.
I had previously thought of using modeling clay to hold the pieces together so that I could flip them over and resin them.
Clay seems a bit messy so I figured that I'd just add a thin layer of fiberglass to hold them which could be sanded away later if needed.
I also worked on a small addition under the hood that I didn't get fully installed, more on that later.
Something to help with a noise issue that I've had.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
sir, this is a stellar build! And that deck is coming out nicely !
2011 Nissan Altima aka Red Ruby
HEADUNIT: Pioneer AVH X2700BS
ELECTRICAL:
-Singer 230a
-Northstar gr34
-(2) Northstar SMS220 w/ Custom Terminals from 12V Metalworkz
-100% Welding Cable
FRONT STAGE:
-(2 Sets) Hertz HSK165
-Hertz HSK130
-Ampere Audio 125.4
SUB STAGE:
-(3) Sundown Audio SA REV2 12's
-Ampere Audio 3800.1 V2
MISC (NON AUDIO RELATED):
-Interior & Exterior Lights LED
-Gloss Black Roof (PAINTED)
-15% Front, 5% Rear Tint
-Roof Spoiler
-20" TSW Snettertons (20x8.5 front, 20x10 rear)
-Custom Projector Retrofit (FX-R 3.0, 6.5k HID, Morimoto Mini H1 (faux projector), Quad Starry Night Halos) ----- COMING SOON!!
-Aftermarket Fog Lights
-Custom Painted Engine Covers
My Build Log: http://www.stevemeadedesigns.com/board/topic/169869-woods-2011-altima-aka-red-ruby-new-video-more-updates/page-109
Retrofit Build Log: http://www.stevemeadedesigns.com/board/topic/185787-hid-projector-retrofitting-diy-by-wood/#entry2765346
Initial testing is coming along nicely so I can throw this out there:
My own version of the TM-1:
:D
Plus lots more room for future expansion.
More to come.......... :ninja:
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
Not gonna lie, that deck looks like a nightmare. Good luck with that. After seeing what you can do I imagine that you won't have an issue doing it.
Thanks Guys :good:
Ohhh yeah the rear deck has been a challenge, that's for sure.
I have a good feeling about it though. I think it should help my numbers a bit, look nice and get rid of a LOT of rattles and vibrations too.
Now hopefully I can get it mostly together before the snow falls..... :ughdunno:
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
So...I had noticed a bit of alternator whine on the right side of my car which has bugged me for quite a while.
It wasn't bad, but was definitely noticeable driving around in a quiet car with no system installed.
My power wire is running down the right (passenger) side of my car so I moved the speaker wires thinking that might be it...nope.
Since the noise was sneakily present without any equipment running (amps, HU, etc), I knew it wasn't in my signal cables or anything like that.
So the noise was coupling from my power wires into my passive speaker wires and getting the speakers to faintly buzz.
My conclusion pointed to the fact that these BMW's don't have batteries under the hood, its in the trunk.
The freshly rectified output from an alternator is going to be inherently noisy and is usually filtered out by a large battery in close proximity (under the hood).
Since my battery(s) are in the trunk, there isn't anything to filter out the noise in the front section of the car.
I have this pocket under my hood which looks to be a perfect spot to house a small battery:
Back when I bought my XP3000's, I also got a lil D375 that I had intended to install as a backup battery.
I'm leaning away from allowing my XP3000's to drain down too far so I've had the battery sitting around for a while.
I figured it'd be worth a shot to install the battery and see if it helps and hey, another battery never hurts :good:
First off, I noticed that my frame ground post wasn't going to be long enough for all the grounds I needed to connect.
I needed to fabricate a small extension bar with a longer bolt:
Here it is installed:
...and after an hour of trying to wiggle my hands in this very tight little space, I was able to thread the bolts and get the battery mounted:
Sorry if the pics are a little washed out, it was getting late and I needed to use the camera flash. I'll get some more pics in the daylight.
After a couple days of driving around.....I think the noise is gone. :woot:
I wouldn't mind doing some actual measurements to put some numbers to the noise.
Plus my trunk area is still completely open and unsealed so I'm getting a lot of road noise into the cabin as well that I need to seal off when the rear deck is finished.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
Mind blowing. I would have never thought that the alternator to battery wire carried a high frequency but it make sense.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
Indeed!
In your home, your wall outlet is 120Vac at 60Hz (single phase).
When electronics rectify the AC voltage to DC, you get a 120Hz (full bridge rectification) ripple voltage riding on the top of the new DC voltage.
That ripple is smoothed out with some capacitors until you get a smooth and flat DC voltage.
In a car (I think my Mechman Alt is 6 phase) you get a varying frequency with the vehicles RPM.
So you could imagine with a 6phase system and a fast RPM, that the frequency of the resulting ripple voltage will be relatively high. Easily in the audible range.
Now unless that ripple is smoothed out, it will induce noise in everything around it.
You can either shield the surrounding components or kill the noise at the source.
I would suspect that most people with the Big3 and batteries under the hood, would never see this problem.
I love XS power accessories. that battery is barely noticeable in there
Yeah, it does fit snugly in that pocket and the pics don't do the aluminum battery holder any justice at all.
It looks way better in the daylight.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
As always, everything looks awesome!! Keep it up dude!
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
  • Who's Online   0 Members, 0 Anonymous, 1041 Guests (See full list)
