1/0 Reducer question...
I have a Planet Audio BB150.4 and wanted to use 1/0wire with 2 reducers (1/0-4Ga) instead of just 4ga wire. When fusing, what size fuse to use since I already have (2) 30 amp fuses on the amp? Would a large ANL fuse work in this situation?
There is absolutely not one need in any possible way at all even a little bit to use 0g on that amp. If, and ONLY if you still feel a need to run 1/0 to it. You still put a 60 amp anl fuse 6" from the battery and if you don't trust the fuses on the amp 6" from the amp as well.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Reason I asked is that ive seen alot of builds with 1/0 with their 4ch amps and I have alot of 1/0 and didn't want to buy extra wire to run 4ga if I didnt need to. Why should I not run it? Would it cause problems for me to run 1/0 instead of 4Ga?
No problems. Just is beyond overkill. Just fuse correctly and it will be fine. Some 1/0 - 4g reducers are pretty big though. I have some stinger reducers laying around that make 1/0 wire look small.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
I understand, but I just want to have that window open for upgrading in the future. Also, I didnt know they made ANL fuses that small! Lol. Im still learning as u see!!
No, it will not cause you any issues. Overkill, yes, but it won't cause any harm.
Ok thanks for all the help guys! I just wanted to know and also keep the upgrading window open!!! Thanks again for all your help!
Why would you put a fuse on the power wire 6 inches from the amp if the amp has on board fusing? It is completely pointless.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
To the OP, it is a waste of 1/0 wire to do that to this type of amp unless the amp was over 25 ft away from the battery it was connected to.
Evo X build log
AMI, I understand your point but wouldnt it be a waste to put the 4ga in and then have to take it back out later on to put 1/0 in? As I stated, I do plan to upgrade later on and if it doesnt cause any issues mechanically as stated from the other posters then this would be a better option for me to just go ahead and run the 1/0
