I have a pioneer avh 2300dvd and I have my 4 channel hooked up and I want to hook up my mono amp. What is the easiest way to hook up the rcas to the headunit? Should I use y splitters? If so how to I do that
hook them into the output of your 4 channel amp. or spliters will work too
Will that work if it's high passed at the HU?
OP try to use the output on the 4 channel like he said but make sure to set the high pass filter from the amp and leave it off on the head unit.
i never understood buying a head unit with less than three preouts.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
If your 4ch amp has outputs on it then use those to go to your sub amp and use the built in pre-amp for crossover settings, you'll lose any control you have at the H/U but it will let you hook it up without having to run more rca's.
If your amp does not have output's then you'll have to split one of the rca's to go to the sub amp.
EDIT: Use the front split for the 4ch and the rear for the sub and you'll have sub control from the H/U.
Edited by Skullz
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   0 Members, 0 Anonymous, 1671 Guests (See full list)
