Kicker S15L7 In 1980 BMW 728 HELP !
Hi Forum !
My Name is Naveen and im from the Netherlands.
This is my first post so dont shoot me if im doing anything wrong.
Equipment:
HU: Pioneer 3200UB
AMP: Kicker ZX1000.1 (Planning on upgrading to the Ground Zero Plutonium 2.3000)
Sub: Kicker S15L7 4 Ohms 2006 version (Planning on adding 1 more)
Car:
1980 BMW E23 728
Problem:
First
In the BMW the bass produced by the kicker isnt comming out of the trunk.
Which is caused by the trunk is completely made out of steel.
Second
anyone has a some good tips of making a Slotport box for this sub.
Build Plans.
(Trunk Dimensions not available right now)
Third
No mather which speaker i wire up to the Hu they all start to crack half way up the volume (which isnt very loud)
HU Broken ? Wire Problem ?
Thanks in advance !
First check how you sub is wired it should be parrell with is both (+) joined together and to (+) on amp that should give you the full 1000rms at 2ohm to sub. That amp is perfect for that sub so no need to upgrade unless you get another sub
How is amp set as well?
What box is the sub in as this could cause issues as well,
All the specs are on there web to build a to spec box
http://www.kicker.com/sites/default/files/SoloBaricL72006.pdf
As for speakers check wiring from head unit and is there an amp to them if so how is it set,
In some early 80 late 70's car they grounded the earth wire for speakers and only ran positive, this should not done with modern h/u
What speaker and amp you have
Hi John
I had first wired the sub parallel, then later changed it to series. (Will wire it back)
The box is an Sealed box and is about 150Liters >see pictures
So you recommend to go for the stock box ?
The settings on the AMP >see picture
There is no amp between the speakers the wires run directly to the speakers. (planning on installing an second amp for the speakers to get rid of this problem)
[/Quote]
Youre Right the rear speakers were still wired this way but i already disconnected those. will rewire that.
PICTURES:
My Car:
https://www.dropbox....%2015.14.45.jpg
Amp Settings:
https://www.dropbox....%2015.15.37.jpg
The Box:
https://www.dropbox....%2015.16.22.jpg
https://www.dropbox....%2015.16.31.jpg
Edited by nahinder
Ok get your trunk max dims while we figure out the speaker problem.
For the speaker problem first enable your HPF o the head unit and set it to 63Hz, if that does not help post the model of your speakers.
Ive enabled the HPF settings to 63Hz which slightly decreased the cracking.
The speaker which came with the car, looks like an Composet but I think it misses the filter (Could this explain the cracking issue?)
Brand is Caliber will check the models tomorrow, I wil also measure the trunk.
Thnx Joe !
First off, fix your gain and bass boost settings. Turn them down. If you go long with those settings you're going to fry your sub very quickly.
My bad, didn't read correctly. I would check all of your wires. Make sure the positives are going to the positives and vice versa.
Edited by Audiojunkie23
Haha ok i will turn those down... all the way ?
Checked the internet
and found the total capacity of the trunk which is 480 Liters
metal plate behind the rear seat:
https://www.dropbox....9h/Naamloos.png
Ive already cut a hole on the red lines
Planning on cutting on the green lines an screwing an MDF plate on it.. Good idea ?
Trunk Dimensions (in CM)
https://www.dropbox..../Dimensions.png
Edited by nahinder
  • Who's Online   2 Members, 0 Anonymous, 1085 Guests (See full list)
