You can also call the guys at Summitracing. They have been very knowledgeable also. I am personally am not familiar with that motor
Good to know. I thought they only sold parts.lol...I'm not trying to build an all out race engine, I just want a bit more "umph" from it, & since I need to change my timing chain, I thought why not change the original cam & chewed up lifters(truck was ran on LOW oil for a while by the previous owner) .
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
You should be good then.... Just make sure that your intake springs go back on the intake valves, and exhaust valves go with the exhaust springs
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
I'm just worried about this cam providing too much lift for the stock valvetrain. I don't want to run into anymore problems with the engine anytime soon. :/
How much more duration/lift are you increasing compared to stock?
Here's the link to the cam kit I got: http://www.summitracing.com/parts/LUN-61605LK/
rocker arms are 1.73 ratio.(stock)
Only thing I would recommend looking into is this: http://www.summitracing.com/parts/LUN-73815K5LUN/
Give Summit a call and ask them for advice about if they would suggest installing new valve spring along with the cam, and of course since they are in the business of making money, they will try to sell it to you regardless lol... But ask them what the pros and cons are of installing new springs or using the old ones.
Start off with:"is it ok to use stock valve springs with (insert cam info here), on a ford 7.5L engine"
Then ask about the benefits of using the spring package that I linked above
How many miles are on those springs? Original springs?
Only thing I would recommend looking into is this: http://www.summitrac...LUN-73815K5LUN/
Ugh, I'd have to pull the heads again! - _ -
I will definitely check in with a few companies & see what they say. I don't know what the truck had been through prior to '07, so idk if they are the original springs.
Thanks for the responses.
No problem at all man. Good luck with the install and I hope it goes easy for ya :good:
Ok, thanks! :drink40:
Short answer is Yes.When running an aftermarket cam,sometimes lift ratios can get extreme enough to need heavier springs.Rockers are not always needed,but again depend on lift and duration ratios,also note that their are different ratios of rocker as well that will change lift stats.Your best bet is to contact the manufacturer of your cam and follow their recommendations.
Good answer
