Okay, I Know there may not be a whole lot of engine experts on here, but since google isn't helping me at this point, I'll just give it a shot.
So my question is: when putting in an aftermarket cam, do you have to match certain rocker arms/valve springs? If so how do you which ones to use?
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
So you're just replacing the stock cam with an aftermarket cam? Just a direct cam swap, correct? If you're reusing the same springs/rockers, I recommend keeping them together. If using aftermarket springs/rockers, it doesn't really matter.
If I didn't make that clear enough, lol, just keep the intake springs with the intake rockers, and the exhaust springs with the exhaust rockers, and label them according to the cylinder it came off of.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
you can also contact companies like Compcams or Cranecams and let them know what motor you have. They would be able let you and recommend a cam. What vehicle are you looking to replace the cam in?
prboboly would have to make sure the engine is at tdc when you install it, and the other standard stuff like lubing it and whatnot, and if the springs and whatnot are stock you may have to replace them to handle the more extreme liff
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Ok, do they absolutely HAVE to be back in the spot, they all look exactly the same?
Thanks for the responses guys, & my cam is coming in tomorrow, lunati voodoo cam (#61605) with new lifters, 241int./249 exhaust. http://www.summitracing.com/parts/LUN-61605LK/
Too late for that.lol. It's an '84 F250 460, 7.5L.
The only reason I say to put them in the same spot is because, if you're not resurfacing your heads or cleaning/replacing your valve stems/guides, the spring/rocker combo might not work as efficiently due to the fact that over the course of the years, that certain valve has been operating at the certain pressure allowed by the spring/rocker.... If you were to get a spring compressor and the compression tester and measure the compression tolerance of the springs individually, you'd notice a difference in compression rates.
That's just my way of doing things though, better safe than sorry. Take off, label, put back on. Easy breezy.
You can also call the guys at Summitracing. They have been very knowledgeable also. I am personally am not familiar with that motor
Ah, I see...valves were cleaned, valve stems & guides were replaced 5 months ago. Heads were resurfaced this week since a gasket blew last week.
