I did that but it didn't change much as far as I can tell.
So theres a problem in your wiring, just unhook one and try it out.
no one has asked what model numbers the subs are. either dual 2 or dual 4 ohm. that is the first thing we need to know to fix your wiring (if thats the problem)
Do you have a built in xover on the HUs subwoofer out? If so- make sure it is set to no lower than 80 hz. And have you put a DMM across your speaker hook ups to see what impedance your amp is seeing?
Could it be these just don't do the low lows?
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
Sub level is all the way up. I played some electronic music and it hit like crazy. It's when I listen to hip hop that the notes are quiet, then the sub gets really loud in certain parts of the song which overpowers the rest of the system. So, the system overpowers the sub, mostly. Then at certain spots, the sub clearly overpowers the system. At first I thought it was the amp clipping or something but even at very low volume levels you can tell the difference. This doesn't seem normal to me at all?
  • Who's Online   0 Members, 0 Anonymous, 770 Guests (See full list)
