Old School: Solo Baric S15D question
I know the old school solo's are designed for sealed enclosures. My question is can multiple drivers share the same enclosure as long as I multiply the air space needed by teh number of drivers used? Or do these subs REQUIRE individual airspaces to work at optimum levels?
TIA
Rolex you sicken me.
Just let me finish my pie
~ Juice
i have been pondering this same thing for a while now , i asked this same question and some one said add the air space for all the subs together for your box volume but i still am not sure about if that would be correct another answer i got was it would sound better with the woofers separated .i have built a box for 2 subs that shared the air space before and it worked ok , not sure if it was correct . i called crutch-field one day to ask this and they said keep each sub in it's own air space , have a divider or build a box for each sub .
they can share airspace. if one woofer requires two cubes two require four etc.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
common chamber box is the most common..
even tho when i run 2 subs,,i do make it 2 chambers just so if i blow 1 sub..i can still rock out with 1 woofer
lol true.
2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood
Mike Singer 250A SHCA and KnuKonceptz wire Big 4+
AQ / Dayton pro mids+monsoon tweets
My Build : http://www.stevemead...35#entry1989435
  • Who's Online   0 Members, 0 Anonymous, 1053 Guests (See full list)
