dhall9 Posted May 14, 2012 Report Posted May 14, 2012 So I haven't even got all my speakers hooked up and my lights are already dimming. I'm getting a solid 1 volt drop when I get a good bass note. You're looking at the green number. So do I need to upgrade the battery or the alternator? I'm thinking battery. I've already done the big 3 with 1/0 wire and I'm running around 750rms right now. Thanks for the input.
Tarball Posted May 15, 2012 Report Posted May 15, 2012 what does your stocker put out? But a good AGM may be what you need but if you have too many accessories the stock alt may not be able to keep up with demand even with Big 3. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
dhall9 Posted May 16, 2012 Author Report Posted May 16, 2012 The stock one I believe is rated at 145 or 150 amps.
Watch the bass Posted May 16, 2012 Report Posted May 16, 2012 The stock one I believe is rated at 145 or 150 amps. Definatly the batt, or your electrical system cause on a other thing. "in the abundance of water, the fool is thirsty" Bob Marley
basshead8569 Posted May 16, 2012 Report Posted May 16, 2012 I would get an High output alt. Then a second battery. Im running 2 rockford fosgate t1500bd at 2 ohms rated according to there birth certs (which I dont go by but I have not tested them yet.) But, that said it can do at 2 ohms 1,850 continuously. I did a 220amp H/O alt and a second battery. Did that when I was just doing 1,800 rms. The H/O alt I would do first. Current system (still building) 2 kicker 12" dcvr in factory kicker ported box, Rockford Fosgate 1200.1 Amp, Kenwood ddx-470 ddin radio, Rockford Fosgate 0 Gauge wiring, Rockford Fosgate punch 6X8 2 way speakers.
Nate Futuristic Posted May 16, 2012 Report Posted May 16, 2012 145-150a at 1600rpms MAYBE (more like 60-90 @ idle) your vehicle can suck up at least 40a with all of your accessories on at one time... adding another batt will give you more "reserve time" but once that battery is drained the Alt will have to pick up the slack AND charge your batteries.... if your straining a stock alt with 750rms then id get a decent alternator and worry about batteries later... or at the very least get a decent deep cycle upfront and see what that does...( try to find a cheap optima deep cycle locally) also depending on your vehicle you can "upgrade" your alternator with a bigger unit that can bolt up to your factory bracket while keeping cost down rather than buying a cheap rebuilt brand or even worse a ebay alt down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
dhall9 Posted May 16, 2012 Author Report Posted May 16, 2012 Thanks for the input guys. The Trailblazer SS has a weak electrical system from the factory. So it sounds like I need to upgrade both, with the alternator being first.
yakofamily Posted May 18, 2012 Report Posted May 18, 2012 need sum help running 4 amps all fosgate 1-t1500 2-p500 1-p200 i have a 110amp alt reg battery up front 2- xs 680 straped together in the trunk my question if i put a xs 1200 battery up front with big 3 all 0awg will i be ok ? thanx for the help brooklyn style
OrzechNJ Posted May 18, 2012 Report Posted May 18, 2012 I got the the battery first.. and I knew that my next step for the system is alt - which I got today.. since I installed it I wasnt listening it when my car was off at all , and I tried to dont drop the voltage below 14 .. sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
