build a 2.5 cubic feet box with a 8.5" aero or 2 6" aeros , everything facing forward, box as wide and as far back on the trunk as you can, port about 17" long or as close as you can to the opening of the trunk, that should give you the number that you are looking for with that equipment...
  • 1 month later...
cool, here´s my 150.1 box using only a loudforce 3500.1 wired at .5 ohms and 2 loudforce 85 series 12" subs wich are 700 watts a piece.
center port, if you can use a 8.5" would give you better results i assume
  • 3 weeks later...
That's a good score for that amp and subs! If you haven't taken out the current box, Port to the side, I see that gaining a little more. If you try rounding sub holes, tape the gaskets, round the port, the one end on the inside and the 4 sides of the outside or at least try some pvc to act like round overs. I would try aeros to the side like you have it. What do you have for electrical? Keep up the work man, you'll get there! 150 with 2 12s and a 3k amp @.5 is very doable just not easy
'11, '12, '13, and '14 Meca Street 2 AL State Champ
AL Meca Street 2 Record Holder(151.6)
2012 Meca Street 2 World Finals - 3rd Place(148.7)
2013 Meca Street 2 World Finals - 2nd Place(151.1)
  • Who's Online   1 Member, 0 Anonymous, 1810 Guests (See full list)
