DC Sound Lab
My 4th order I buil was 2.5 sealed and about 4.8 ported, I would definitely go with 2:1 ratio. I think it would best. So If u wanna go 3 sealed run 6 ported! Do it you will like it if you build it they will come!
I did this with single 18 had great sucess, 136inches of port maybe bigger 155 ish
Had 3 cubes ssealed6 ported if you can I could do 3 sealed 7 to 9 ported with more port
Look on caco look up y 4th orders arnt loud hanchmunch or something has a ton of good info too!
you want to tune the ported chamber to the resonance of the sealed chamber :good:
Thanks ray for all the great input :)
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
Ok then just bring yr 18s. And I just build a 4th for all 3 in the blazer.
2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz
19 cubes net 245sq in of port
Sundown 3500 @ .7 Ohm
Sundown 100.4
Rockford Fosgat Power Series
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
1 red top under the hood
2 yellow tops in back
big 3 with 1/0 knukonceptz wire
3 runs of +/- 1/0 knukonceptz wire
IT LBS
So how does 3sealed and 6 ported with 155 sq.in of port tuned to 43hz off a sundown 3500 at 2ohms sound ?
Sundown 100.4
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
IT LBS
3 sealed 7 ported tune to 48 imo I like the port area :good:
43 seems a lil low
And y run at 2 ohms? Not lower?
Edited by CortezDTV
SCSB
Build logs:
2:1 ratio isn't always best.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
43 seems a lil low
I want it to play low . This is going to be a temp box till I get more subs.
It will really be at 1.4 had a brain fart that day when I put that. I was running 2. 18s at .7 but one gave out.
Sundown 100.4
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
IT LBS
What berto said is right tho^^^^
U can always go bigger on ur ported area to increase the ratio, if u add power ull want a small sealed big ported ish
Ideally you want to tune the ported section to the resonance of the sealed section so build that first then put the loading wall on last with the port tuned to that sealed resonance in the car :)
SCSB
Build logs:
So do i have to tune it to the sealed resonance of my blazer even though i only play with my windows down?? I dont do comps.
Sundown 100.4
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
IT LBS
  • Who's Online   1 Member, 0 Anonymous, 693 Guests (See full list)
