Let mi know what you think? My 2nd 18 should be here Wednesday!!
~Team Nussiance~
Head Unit: Sony MEX-BT38UW
Amplifier: 1 AQ2200d for break in period
Subwoofers: 2 AQ HDC3 18's
Mids and Highs: 1 pair of AQ PA-6.5's and 1 pair of AQ PA Supertweets
Scores: 148.1db @47hz
146db- Dash
143.8db- Headrest
Both on music
i'd do a center port along the bottom or in the center. you might run into loading problems with that current port design.
like the others said, 2 common walls would be better in this situation. i can almost guarantee you don't have 3 quarters of a cubic foot worth of bracing displacement in that box. and even if you do, you don't need nearly that much. i'd say a quarter of a cubic foot at the very maximum. your sub displacement is off as well. the HDC3's displace around .2-.25 each. You accounted for two *extra* baffles in the calculator, but I only see one extra in your drawing. you should really only need one extra baffle anyways, so enter 1 for the # of extra baffles.
if you're using the HDC3's they're probably going to want a little more airspace. so try to get 12.5-13 cubes net.
Edited by 412 CVX
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
