I don't think I'll have any issues with port noise. If I do, I'll just cut out the port, patch the box, and go with 3 6 in. Aero's. I just don't want too much port area and unload, or not be musical enough.
lol i think you will. the minimum "recommended" is 12. you have 10.8. too much port area is like 18sqin per cube for a slot port LOL. and even then you have people doing 20-22 for their subs
are you sure its a cherokee and not a grand cherokee. if those measures are correct and its a cherokee you must not have the spare tire in or anything. you should have enough room to use the 15's how much power do you wanna run
Posted (edited)
But than, if I build the box to minimum Obsidian recommendations, my port area is great
I think it just looks small because I built the box to maximum recommended size. We're not talking about 3000 Watt subwoofers, or burp machines here...
Edited by BobbyG2
*New vehicle and system coming soon.*
TOOK THE SPARE OUT TO HAVE MORE ROOM /RELOCTED TIRE TO ROOF RACK I ORDERING A SKAR 1500.1 SUBS WILL BE RAN @ 2OHMS SO THINK ITS ABOUT 1000 WATTS AT 2 OHMS UNLESS YOU GUYS THINK MY MASSIVE WILL BE STABLE AT .5 OHMS
4 kicker ks 60
1"AMERICAN BASS DOMES
RE DTS 80X2
AMERICAN BASS xd2000
2 OBSIDIAN 15D2
ALL KNU WIRING & RCA
THE BIG THREE
1.5FARAD MASSIVE AUDIO CAP
2.0FARAD MASSIVE AUDIO CAP
98 JEEP CHEROKEE
avic930
optima red top
american bass sq2000
The first box I posted should work. Maybe a little more port area I guess. Download Torres Box calculator and fool around with it. Obsidian recommends 2.5-3.75cu.ft. (net) so 5-7.5cuft. Net for the pair. They recommend somewhere between a 4"-6" aeroport per 15, but everyone here seems to think that's not enough port area. Subs up, port rear (make sure there's at least 6" between the port exit and the hatch). Maybe build it on the big side if you're only putting 1000rms to the pair. And you should be good! :)
COULD HELP ME WITH SLOT PORT BOX INSTEAD AREO I DONT LIKE USING THEM AT ALL
4 kicker ks 60
RE DTS 80X2
2 OBSIDIAN 15D2
THE BIG THREE
98 JEEP CHEROKEE
avic930
optima red top
Ok so here is a suggestion within your dims sub up/port back, tuning as requested:
Enclosure Specifications:
Fb = 30 Hz
Vb = 7.4 ft^3
External Height = 20 in
External Width = 40 in
External Depth = 26 in
Port Width = 5 1/2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 40 x 26
Left & Right Sides = 24 1/2 x 17 3/4
2x Front = 17 1/4 x 17 3/4
Back = 40 x 17 3/4
Shared Port Internal Assembly Parts:
2 x Front to Back = 21 3/4 x 17 3/4
2 x Extension = 1 7/8 x 17 3/4
Assembly guide (generic dimensions);
Net volume and port area are within limits. Let me know any questions.
SWEET THANKS JUST WHAT I WAS LOOKING FOR
4 kicker ks 60
RE DTS 80X2
2 OBSIDIAN 15D2
THE BIG THREE
98 JEEP CHEROKEE
avic930
optima red top
I JUST WANTED TO SAY THANKS TO EVERYONE FOR GIVING ME INFO I HAVE NOT RAN ACROSS ONE PERSON ON THIS FORUM THAT WAS NOT HELPFULL
AGAIN THANKS TO ALL!!!!!!
4 kicker ks 60
RE DTS 80X2
2 OBSIDIAN 15D2
THE BIG THREE
98 JEEP CHEROKEE
avic930
optima red top
That port has to be RIGHT up against your hatch dude. That's why I fired mine to the side.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
  • Who's Online   0 Members, 0 Anonymous, 739 Guests (See full list)
