Mtnbikecrazy55 Posted May 25, 2012 Report Posted May 25, 2012 Oh and fyi- flange bolts have a really weird head on them and a fine thread. Finding copper nuts that would matte with the flange bolts may be tricky. Just tryna give you a heads up I hate long signatures.... ...what the fuck is wrong wiht you you fucking fuckity fuck fuck head... Mtnbikecrazy55 Feedback
AMI CUSTOMS Posted May 25, 2012 Report Posted May 25, 2012 Save yourself some time and just go to mcmaster Carr.com and get exactly what you need great prices and will be there in 2 business days. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
purplesyrup Posted May 26, 2012 Author Report Posted May 26, 2012 Save yourself some time and just go to mcmaster Carr.com and get exactly what you need great prices and will be there in 2 business days. sounds good to me
snafu Posted May 26, 2012 Report Posted May 26, 2012 Is there a benefit to using one bolt over another? Here would be the simplest way to determine this: Install bolts (one for positive, one for negative) in a piece of wood that is the same thickness as the enclosure Wire amp to bolts and bolts to subs with ring terminals as you would normally Grab TWO quality DMMs, each with a MIN/MAX scale and set both to measure AC Voltage METER 1 - Put the red probe on one side of either bolt (at the point the rings contact it), the black probe on the other METER 2 - Put the probes on the speaker outputs of the amplifier (be sure to set the range to it's maximum setting) Crank the system, then enter the MIN/MAX mode on both meters to record voltage over time Play the system at near maximum output for at least 30 seconds on bass heavy material End the MIN/MAX recording session and then reduce volume accordingly Note the MAXimum voltage each meter recorded over this period of time: - METER 1 shows the voltage drop across each bolt - METER 2 shows the maximum voltage the amplifier made Voltage recorded via METER 1 *2 / Voltage recorded via METER 2 = %age of voltage drop across the bolts Repeat for as many different kinds of bolts as you like and log the data. Is this meaningful? My hunch would be to say NO, but why not find out for sure? Guys, isn't it time we all stop guessing at this kind of stuff when it's SO easy to know the answer with certainty? Tony Candela - SMD Sales & Marketing Email me at [email protected] to learn about becoming an SMD Partner!
HunterJohnson Posted May 26, 2012 Report Posted May 26, 2012 its bc of lazinessssss i use aluminum bolts on all of my boxes Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
purplesyrup Posted May 27, 2012 Author Report Posted May 27, 2012 I went to the suggested website, no copper bolts, This whole mission has been a total fail, I have only found 2 copper bolt listings, both on ebay, and they are not long enough. I never knew it would be so hard to get copper bolts. They had copper washers for $1.20 each, so 6 times the price of a standard washer. if the bolts were 6 times the price they would be about $5 each, nuts around $3 each (educated guess) So, 1 bolt, 4 washers and a nut, $13 per wire, need 4, $52 for an efficient power transfer with e clean look for a quick ohm load change. Pretty pricey but copper is high now. Everytime I search copper bolts online, it pulls up all these sites only showing brass, Bingo, just thought of something............
AMI CUSTOMS Posted May 27, 2012 Report Posted May 27, 2012 Use brass TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
purplesyrup Posted May 27, 2012 Author Report Posted May 27, 2012 1/2" square copper rod, have it cut into 2" pieces, drill 1/4" holes for the 8ga copper wire ends, bolt it together, also have to figure out how to secure these to the box. Closest thiing I can think of, http://store.electri...loy-c11000.html or the rod http://store.electrical-insulators-and-copper-ground-bars.com/copper-rod--250.html
AA98hoe Posted May 27, 2012 Report Posted May 27, 2012 Just hard wire it bring 4 wires for each sub outside the box and do all connections there.. what amp subs and ohm load do u plan on changing too.. I will never run at high ohm load..there's just no output.. TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
purplesyrup Posted May 27, 2012 Author Report Posted May 27, 2012 D2 VC, bridged @1ohm, then a coil on each channel, 2 ohm on each channel, then, i will getting a different amp, then possibly adding another, I dont want to mess with twisting wires together, I want the install to be as clean as possible, and once the sub is mounted, dont want to have to pull it back out
