the wiring would be easy. power wire to what you want to watch the voltage on (amp, batt bank, alt, distro block, front batt), remote to h/u remote, negative to closest ground. not rocket science, if you can wire an amp you can wire a voltage meter.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
YES my order has been placed ..Too bad the code dosent work anymore :(
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
Did you copy-paste? If there are any spaces before or after the code it won't work. I didn't see a time limit on the code.
Yes i did and it said that this coupon was no longer available ??
I got my order in for one of these and i want to go ahead and get the wires run so when it gets here i'm ready to hook it up.
My question is would 14ga wire be overkill for this,since i already have some on hand?
Also can you tell us how it is mounted?
You fail.
14ga will be fine
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
