Power Wire From Battery MELTED Into
Eventually the power wire (4 gauge) MELTED into.
im still trying to figure out what this means
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Am I seeing things or is the boot and some sort of rubber grommet UNDER the ground wire? And is there even a terminal on the wire or did they just smash bare wire down under the screw?
My friend recently bought an Orion HCCA 15" sub and Orion amp, and let me borrow his old setup until I buy mine in a week or so. It was a Sony Xplod 12" with a pioneer amp rated at 760 watt max. I had it installed in my 2005 altima, and the inline fuse kept blowing, and the tech guys kept putting stronger fuses in. Eventually the power wire (4 gauge) MELTED into.
My thought is that you should take it back to where you had it installed and speak to a manager. If they fused the wire with a higher amperage rating than the wire is meant to carry then they put you in a bad situation and helped cause this mess. They should have troubleshot the reason the fuses kept blowing instead of doing a hackjob fix by just increasing the fuse rating until it stopped popping. Unless you told them you couldn't afford them to do the troubleshooting
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
  • Who's Online   0 Members, 0 Anonymous, 1221 Guests (See full list)
