Ok so i have 2 L7 15's
i want to know if it would be ok to build a wall
or just a box, i have plenty of space for either
i want it to get loud on the lows. real low!!
another question what kind of port do i need to get real low
aeroport or regular etc. and what kind of box as in like ported
4th order ect? help me out please
kicker recommends not going over 12 cu ft for the 2
just sayin
Wall 'em! I've always wanted to build a wall for 15s sometime in the future.
*Daydreaming* :)
And as for the box designs, there are many different factors and hard to tell which one is the best suit for you. You probably have to "play around" until you are happy with the setup. That's all I know.
What port will come down to box and design
Idd build 7net for each with 90-95sq" of port each
Yes it's a bit small on the port but work well with theis on full tilt
How much power you throwing at them?
With the biggest vented box, 15"L7 can only be able to take at least 750rms (based on the manual from Kicker.com). I'm sure it can be able to take bit more than that with the right box and power. :)
I had my single in 7net loww 30's tune on zx1000.1 birth was 11xx rms
And it ran like that for over 1 year till I sold that setup and got a cvx15 to replace it
I did however have the gain set with an oscilloscope
7 Cubic feet each? isnt that a little to much?
im not an expert on boxes but kicker says 12 cubic feet total for 2?
just confused. but thanxs and what do you mean by full tilt?
i got 2 t1500's one for each. wired to 2ohms so like 1600 to each sub.
1600 each is a bit to much power for theis subs there only rated at 750
I ran mine a 1k and they handled it but 1600 idd be dropping that box right down at that power
Edited by john253a
The biggest box a single 15"L7 can reach is 6.0 cu.ft. So for two 15"L7, at least 12 cu.ft is about right. And as for "full tilt," it means that you turn the volume all the way up and thus pushing those subwoofers to the limit. And lastly, I highly doubt that sub can "see" a truly 1,600wrms from the amp that you have. But again, I've seen some people throw much higher than what RMS may suggested on the paper with the right & clean power, box, etc. However if you don't know what you're doing, then I suggest to feed subs at least 1,000wrms or just watch the gain.
-Smurfboy
