AKT6190 Posted May 27, 2012 Report Share Posted May 27, 2012 Ok so i have 2 L7 15's i want to know if it would be ok to build a wall or just a box, i have plenty of space for either i want it to get loud on the lows. real low!! another question what kind of port do i need to get real low aeroport or regular etc. and what kind of box as in like ported 4th order ect? help me out please kicker recommends not going over 12 cu ft for the 2 just sayin Quote Link to comment Share on other sites More sharing options...
Smurfboy Posted May 27, 2012 Report Share Posted May 27, 2012 Wall 'em! I've always wanted to build a wall for 15s sometime in the future. *Daydreaming* And as for the box designs, there are many different factors and hard to tell which one is the best suit for you. You probably have to "play around" until you are happy with the setup. That's all I know. Quote Link to comment Share on other sites More sharing options...
john253a Posted May 28, 2012 Report Share Posted May 28, 2012 What port will come down to box and design Idd build 7net for each with 90-95sq" of port each Yes it's a bit small on the port but work well with theis on full tilt How much power you throwing at them? Quote Link to comment Share on other sites More sharing options...
Smurfboy Posted May 28, 2012 Report Share Posted May 28, 2012 With the biggest vented box, 15"L7 can only be able to take at least 750rms (based on the manual from Kicker.com). I'm sure it can be able to take bit more than that with the right box and power. Quote Link to comment Share on other sites More sharing options...
john253a Posted May 28, 2012 Report Share Posted May 28, 2012 I had my single in 7net loww 30's tune on zx1000.1 birth was 11xx rms And it ran like that for over 1 year till I sold that setup and got a cvx15 to replace it I did however have the gain set with an oscilloscope Quote Link to comment Share on other sites More sharing options...
AKT6190 Posted June 1, 2012 Author Report Share Posted June 1, 2012 What port will come down to box and design Idd build 7net for each with 90-95sq" of port each Yes it's a bit small on the port but work well with theis on full tilt How much power you throwing at them? 7 Cubic feet each? isnt that a little to much? im not an expert on boxes but kicker says 12 cubic feet total for 2? just confused. but thanxs and what do you mean by full tilt? i got 2 t1500's one for each. wired to 2ohms so like 1600 to each sub. Quote Link to comment Share on other sites More sharing options...
john253a Posted June 2, 2012 Report Share Posted June 2, 2012 (edited) 1600 each is a bit to much power for theis subs there only rated at 750 I ran mine a 1k and they handled it but 1600 idd be dropping that box right down at that power Edited June 2, 2012 by john253a Quote Link to comment Share on other sites More sharing options...
AKT6190 Posted June 2, 2012 Author Report Share Posted June 2, 2012 mine are rated for 1000 but can handle a bit more. but what do you mean drop it down at that power? Quote Link to comment Share on other sites More sharing options...
Smurfboy Posted June 2, 2012 Report Share Posted June 2, 2012 What port will come down to box and design Idd build 7net for each with 90-95sq" of port each Yes it's a bit small on the port but work well with theis on full tilt How much power you throwing at them? 7 Cubic feet each? isnt that a little to much? im not an expert on boxes but kicker says 12 cubic feet total for 2? just confused. but thanxs and what do you mean by full tilt? i got 2 t1500's one for each. wired to 2ohms so like 1600 to each sub. The biggest box a single 15"L7 can reach is 6.0 cu.ft. So for two 15"L7, at least 12 cu.ft is about right. And as for "full tilt," it means that you turn the volume all the way up and thus pushing those subwoofers to the limit. And lastly, I highly doubt that sub can "see" a truly 1,600wrms from the amp that you have. But again, I've seen some people throw much higher than what RMS may suggested on the paper with the right & clean power, box, etc. However if you don't know what you're doing, then I suggest to feed subs at least 1,000wrms or just watch the gain. -Smurfboy Quote Link to comment Share on other sites More sharing options...
monteboy05 Posted June 2, 2012 Report Share Posted June 2, 2012 Yea I would do that to more power Quote Team bassin chevys Link to comment Share on other sites More sharing options...
