help lol
im getting into car audio and am about to move to phx arizona ... going to try to apply at a shop and get going....
see if you can answer my question... im going to create a cenario ( im newb trying to learn)
On a Crescendo BC5500D:
Rated Power Output(RMS)
Clean RMS power on 13.8v standard electrical system:
Ohm Load
BC5500d
1ohm
5800
2ohm
2800
4ohm
1500
and a DC XL 12 voice coils:
D.7/D1/ D1.4/D2....
So the amp... if ran at 1 ohm, produces 5800 watts.... so you want to run 1 ohm or ive heard of running 0.5 ohms... "Stable down to .5ohm on strong electrical" right off crescendo website... the 12 has two voice coils so if you have dual 1ohm coils.... is that a 2 ohm off the amp? dual 0.7s = 1.4 ohms.... how does this work? ALSO IS THEIR A BOOK I CAN BUY TO LEARN A LOT OF STUFF LIKE THIS AND STUFF I NEED TO KNOW!
a d1 can be ran at either 0.5 or 2 ohms depending on how you wire the voice coils. parallel wiring would result in a 0.5 ohm load while series wiring would make it 2 ohms.
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
First look up Ohms Law, then go to the general audio forum and look at the pinned "Snafu" posts.
well everything you need to know can most likely be found in this forum with some research. d1 is dual 1 ohm. parallel wiring is + to + and - to - on the voice coils. series is + on one coil to - on the other. then the + and - left over go to the amp.
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
ok... anyone got like a .... diagram type thing with a picture wth a sub and amp hooked up with labels... or with multiple subs hooked up?
http://www.the12volt.com/caraudio/boxcalcs.asp
skar sk2500.1
alpine HU
2 x-15 sundowns
  • Who's Online   1 Member, 0 Anonymous, 1383 Guests (See full list)
