Turning My Show SQ -Denali into EXTREME 20K WATT GROUND POUNDER!
hey look at that im proud to be a Canadian lmao
REP
The C-Pillar Wall and baffle were complete along with back wall.. then I realized that 4 SP4 18's and 15k watts might not make me the loudest ground pounder in Ontario.. So The build was tore out and now doing a build that is TWICE as big in every way.. Not sure if I should make a new thread or continue here.. I do have updated pics as well..
were you scared :peepwall:
Yes, I WAS scared.. But not an issue anymore :) Should be doing over 160 on music.. but we shall see. :)
i wish i could fit 8 18s :D
you can with a sawzall or plasma cutter. :D
i could, but my 14cubes ( NET) is working pretty good for now!!! plus if i did a walkthrew.. id need more wire, and have to redo bag setup in rear.. thats to much work haha
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Yes! Pic whores gonna pic whore! Post em up! And keep this thread updated!
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
Pics are on my phone.. But I am going to check on progress and see my truck in two days so will get some more then u/l. Since everything was tore out right to metal including all seats.. skins.. headliner etc. All there is to see is a bunch of sound deadening and a steel cage being built that can hold King Kong. I guess i could show the door pads and rear hatch since they weren't really ripped apart like the c-pillar wall was..
damn...when did I miss this?
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Ok guys.. since there seems to be some interest here.. and I've been slacking I apologize. Just to clarify once again. The build has changed a lot since it started.. Original Box / Cpillar Wall was ripped out as you can see here.
The Deadened.
The a STEEL CAGE / FRAME was built
Was able to keep my Lambo doors as well but had to upgrade to lot better kit. went with LSD and a lot heavier shocks due to some extra weight in the doors.. not sure if I should post door pics or not since I plan to battle Robin Butler at SBN 2013. I can say that a few more Selenium items were recently ordered along with more amps :)
