What's up guys? Got a quick question. I have a mechman 270 amp alt in my tahoe and a d3400 under the hood. I also have the big 3 and 2 runs of wire to the second battery in the back. All the wiring is knukonceptz. I'm only running 3875 watts and I'm still getting voltage drop bad at idle. Any suggestions as to why this would be happening? I'm honestly not sure if the voltage drops while driving because I haven't looked yet. I just got my digital volt meter in so I'll hook it up asap. Thanks!
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
what exactly are you calling bad voltage drop? 11?12? volts
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Take your RPM up to 1500 and see if you drop. Alternators don't do full power at idle that is why a lot of competitors will ramp up their idle when in the lanes, so the Alt puts out more power.
Edited by Hotdog
cause at idle you aren't getting full out put of your alt. it should be much better when your revving the engine or driving around.
very true was just wondering how bad hes dropping exactly..
power: dd m4
when i glanced at it, it was dropping down to around 12
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
rev the engine. that thing probably outputs like 180a at idle. which would make complete sense
Edited by Kranny
ok, I'll try that and let you guys know how it works then.
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
  • Who's Online   0 Members, 0 Anonymous, 1058 Guests (See full list)
