1 sa 8v2 sub box
something like this might work for you, you could even do sub up as well with same box,
i can change it up if you want, to standard L-port, just that in my test of thesis subs, they love the lows and need a bit of space at rear
This project comes up all the time, simple L port alternative:
Enclosure Specifications:
Fb = 35 Hz
Vb = 0.72 ft^3
External Height = 10 in
External Width = 22 in
External Depth = 12 in
Port Width = 1 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 22 x 10
Left & Right Sides = 10 1/2 x 8 1/2
Top & Bottom = 22 x 10 1/2
L Port Internal Assembly Parts:
Front to Back = 9 1/4 x 8 1/2
Extension = 16 1/4 x 8 1/2
Assembles like this:
Can be re-tuned if needed.
Thanks guys i have already cut all my pieces for the design that john made me im assembling as i write but if the t-line doesnt convinces me ill switch it up to a normal ported L shape box.
Thanks for all the input.
It's not a t-line
It just a different way of doing the port to allow the sub to have more airspace behind it
To do a t-line for this you would need 50sq" of port 96" long and that doesnt quite fit in the area you have avaible
It's not a t-line
Oh ok anyways thats what i did its drying ill let u guys know how it sounds in a couple of days
I did 40 inches of port area for my sa 8 v2 t line. Tuned in the upper 40's right now. Wish I tuned it a little lower, but it is impressive for what it is. Going to build a second one tuned lower when my second 8 arrives.
formerly known as Blue86f150
this sux camel dicks
That's what ive found works this this sub
Tuned at around 35hz
Edit
Without running all the numbers for and exact sq and length, you'll find that pretty close going from memory
The inner dia of that sub is 7.25 if i remember right which would result in a port area of ~41 inches. 50 is a little more port area than needed, T-lines are better when precise, but if your experience is good then thats cool that it worked out
As I said before thoes numbers were from memory and wernt exact,
I've now tried 2 t-line boxes for my v2
1 was 90sq" of port 96" long
and
95sq" 100" long
both were very loud on 100rms each (final load of 8ohm) I'm yet to run them at 2 ohm 200rms each or even 0.5, 500rms each,
Once there loosened up a bit I'll juce them a bit.
I'm in the process on building another 85sqin 200" long that can be split at 100" long to try both options, for a home audio set up,
I'm yet to drive my v2s over 100rms in a t-line each yet,
My v1.5 run at 500rms ea in 0.6cuft at 32.5hz, in the trunk of my car and I'm
Pretty happy with them
  • Who's Online   0 Members, 0 Anonymous, 8260 Guests (See full list)
