sorry but i saw this and wanted to ask when is a Amp Relay / Battery Isolator needed when adding another battery?
i've been told that they are useless, just a marketing scheme. IT'S JUST WHAT I'VE HEARD THOUGH! and i wouldnt mind hearing other opinions also!
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
Like this:
Batt----fuse-------------------fuse----batt
And get the fuses as close to the battery's as possible so you have the least amount of unprotected wire as possible to short out on something and catch on fire. And make sure you fuse to the wire's rating. So if your wire is rated at 300A use a fuse no larger than 300A.
cant believe no one clarified that you fuse both ends of the POSITIVE wire. dont worry about the negative/ground.
I have pos and negative both connected to each other. Am I losing power with long ground?
im assuming you dont actually mean the + and - wires are connected together and you really mean you have runs to the front battery for both + and -.
and the answer is, no. you can easily have less resistance with a - run front to back. copper will have much less resistance than the steel chassis.
you use a relay if you plan on playing your stereo with the car off. then you can always start your car even if you drain the rear battery. as long as you aren't stupid like that though lol you wont need one.
Like this:
I said the positive wire needs to be fused, a few posts above.
  • Who's Online   0 Members, 0 Anonymous, 1196 Guests (See full list)
