1/0 wire not fitting into 1/0 terminal
Ok so a week ago I installed some 1/0 kunkconceptz wire & ran it to my 2011 zx1500.1 I had to cut a few strands off to make it fit but if I move the wire at all it keeps coming out...any ideas of how to fix this?????
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
Did you tighten the wire in the amp? it shouldn't come out. Also Knu 1/0 is closer to 2/0.
I tightened it as much as I could,everytime I move it it.keeps breaking off and coming out...
try to solder the end of it, so once you tighten it down, that soldered part wont be able to come out..
It don't matter how much he solders it. If its still loose it is not making a very good connection either way.
I don't know how to post pictures, & I cut like 50 off mybe....I do have a good amount of slack and my amp slides around when I drive but the connections should be more solid. I just mounted the amp to the floor hopefully that will help
  • Who's Online   1 Member, 0 Anonymous, 1403 Guests (See full list)
