zxsonnyxz Posted June 4, 2012 Report Posted June 4, 2012 ...I do have a good amount of slack (!!)and my amp slides around when I drive(!!) but the connections should be more solid. I just mounted the amp to the floor hopefully that will help Didn't anyone else read this part? Yes, it should help. Quote STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback!
8ight Posted June 4, 2012 Report Posted June 4, 2012 Is it by any chance alluminum? (where you keep having to tighten it) I've never had problems with aluminum, you tighten it down and it doesn't come loose unless you un-tighten it, albeit even ever so slightly... Quote I'm gonna hate
Riley Evan Houser Posted June 4, 2012 Report Posted June 4, 2012 Generally alluminum doesn't set Quote
