I have a weird sound coming from over the front drivers side tire. It does it at idle. It sounds like when you pull up a zipper except it's
constant until you rev the motor. and sometimes it fluctuates. Almost like a zippery whining sound. It has always done it but I just seem to be noticing it more now for some reason. I've asked people and they go oh It's nothing. Just would like to know what it could be. Almost like something spinning.
Engine is an Ecotec 2.2L 2006. Thanks
How could it be the CV Joint if it makes the noise at idle and goes away when you rev it lol.
How do the belts look?
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
Check the power steering fluid level. Sounds like a belt or the pump might be making noise. Go to the parts store and grab a can of belt dressing and while it's idling spray the belts. If it goes away, you found it. Sometimes the power steering pumps growl meaning low fluid or pump going bad. If you see fine silvery metal in the fluid, then that means the pumps on its way out.
The belts tend to sound like a clicking sound and do go away at higher rpm. The belt dressing or a spray bottle with soap and water in it will tell you if it's the belt. The soap and water will go away and the noise will come back, the belt dressing sometimes will quiet it up permanent or it will come back depending on the condition of the belts.
That makes sense.
I'm a mechanic and troubleshoot and fix garbage trucks for the #2 garbage company. I run into this kind of stuff everyday.
post-2214-0-94456300-1338760075_thumb.jp
this sound like the possible problem?
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
