i can make a video if you want.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
Ohms has NOTHING to do with clean or dirty signal. Input voltage and gain level has everything to do with clean dirty. It's all about matching gain level from HU and amp.
gotcha, . . . . so on another note for a second. how can ou get you ipod to play all songs at same volume, theres a fthing that doe that right? that way you can set with say -10 db and should be fine on everything, instead of just some, yeah?
i have a kenwood, same settings as you, 35 of 35, not distortion. i set my shit with -5 db, and let it ride. If you set it with the dd-1 on track 5 or -10 and shit is bottoming out, set it with -5, the wave of the song might not be clipped but may have a higher amplitude than you think which might be causing the sub to bottom out or get to much power.
also, as an example, if you have a 2000 wrms amp, on a 1000rms sub and you set it with the dd-1 and it bottoms out, it is probably due to the double rms, not clipping and so on. that skar is 600rms and that amp tested by ray does around 1000-1100 iirc. That is called overpowering. Plus we dont know box specs or anything like that. I would set the EQ flat, do track 3 (-5 @ 40) and see how it is. If it bottoms out, turn it down, if it doesnt good for you. You need to see what amplitude the wave on that song is for whatever frequency. Unclipped -3db wave will still bottom your shit out if you have it set with -10db.
im running at 2ohms so most i should be getting clean is about 600rms. and skar are known to be underrated as well. .. not sayin ur wrong jbut just notin the fact.
yea, just test to see if the HU clips at +15, if it doesnt, just use it like that.
the model i have that clips at +1 sub volume is KDC X595.
no no i know that lol. i quoted someone from earlier. who said i am overpowering my sub and that could be why. i said no because ray clamped clean at 1100 at 1 ohm. im running at 2 ohms. meaning the sub is only prob getting 600rms clean. . .the amp is rater 1500 1 ohm and 900 2 ohms so if its clean 1100 at 1 i assumed somewhere arnoudn 600ish clean at 2 ohms..... ruling out that its prob not overpowering issues......
ill check it all tomorrow
I just went to check and it goes up to 10 not 15. and i use -5 on my amp to set the gains.
Battery = XS D3400
Sub= Kicker L7 12"
