Kenne Bell 2010 Mustang GT: Speed (slow) and Sound Build
What's the update on the engine issues?
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Both cats and the H-pipe (its one big assembly) are being reluctantly replaced by Ford under warranty, on Wednesday. Once that is done, ill be doing the compression check on the cylinders and leak down tests if any low compression is discovered.
I just want to be sure the heads/valvetrain are in good shape before building the bottom end and doubling the boost.
SMD Super Seller
My Feedback Thread
Have you checked out the head at all?
oh lawd.
Didn't know these existed (thanks Keith77), borrowed it from Autozone. The coolant tested clean of combustion chamber fumes, meaning my head gaskets are likely good. Im happy, except I already bought new head gaskets and head bolts.
SMD Super Seller
My Feedback Thread
Even better is that you don't havet o change them hopefully. is the cat swap done?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Ford has the parts, taking the car in Wednesday morning. Then I can really get down to figuring out this misfire stuff. Plugs are straight, no coolant in the cylinders (or oil), all coils and injectors are firing. I am hoping the cats were causing the issues all along. If not, it has to be in the tune somewhere.
One thing at a time, though.
SMD Super Seller
My Feedback Thread
Yeah i know it's tough to not make a bunch of changes but it can make things overly complicated if you start doing that
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
