BassBarbies Ford Edge Build Sundown,Shok, Project DB, Pioneer
Here is the box somewhat completed.
Don't Let the Pretty Face Fool You, I Roll Like a BOSS :D
2008 Ford Edge SEL
Pioneer Avh-4400 Head Unit
2 Sundown Z V.3 12"s
Mechman 270 Amp Alt Externally Regulated
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Lots of Stinger Road Kill Deadner
152.1 DB Legal TL Score (for now)
Build Log
http://www.stevemead...dge-sa8s-build/
Looks great! How did u find all the angles for that port!? I seriously suck at angles
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
It looks like a pretty sweet box, the octagon port looks way better then a plain old round port also.
I agree they look so much more unique. This setup is loud very impressive for so 600 watt woofers
2008 Ford Edge SEL
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Build Log
360/8 is the angles that you need to cut
formerly known as Blue86f150
this sux camel dicks
nightshade definitely knows what he's talking about. he's been MIA for a while, but he's no noob.
the port looks really good there. not sure how often you plan on taking out your box, but wing nuts on the last set of wires (that go from the amp to the box) might prove useful. but....seeing how you're as into car audio as you are...i wouldn't doubt you carry a toolbox in your car, so grabbing a ratchet might be just as easy
and twostrokeking....each angle is just a 45º cut
Thanks man! Why is it divided by 360 tho? Sorry, just tryin to learn :D
My Truck Build
because the angles add up to 360. picture doing a square port, and you'd need to find the angles to make the square. divide 360 by 4, and you get 90. each angle is 90 degrees (obviously) and all 4 add up to 360.
A full circle is 360 degrees and any 2D shape will always add up to 360 such as the square like Torres suggested. You simply divide 360 by how many points the shape has to get your angle (this is assuming it is a symmetric shape). Get yourself a protractor, it should help with getting an understanding of how angles work and help find unknown angles you need to know.
