This is probably a stupid question but what are Direct Leads and what are the advantages of them?
Thanks guys!
There is no stupid question, but the can always be stupid answers. :)
Direct leads = no push terminals. Just wire that comes straight off of the tinsel leads. I'm not sure if it's been proven to be better or not. I've never had a problem with push terminals.
Thanks man
2012 Jeep Wrangler 3.6 W/ 6 Speed
Build Log
2011 Ford F-150 SVT Raptor 6.2
Build Log
YouTube
There is nothing wrong with push terminals DD made direct leads as a sale gimmic and to save money the save 5 bucks a sub not putting on push terminals times that by a thousand subs sold DD just saved 5 grand and made you think it was better for doing it
Some good marketing right thuurrr
less resistance to your sub = potentially higher score on a TL. you most likely couldnt tell the difference between direct leads and terminals on a sub unless they are some very resistive little phuckers.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Best benefit I see is it's easier to use 8ga + for speaker wire. Pretty hard to put 2 pieces of 8ga into 1 push terminal (without cutting any stands). No sale gimmick there.. just just common sense.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Same resitance there is still a connection being made from the tinsel to the lead fyi
I tested it good try tho just a sales gimmic
yea i tested .1 ohm resistance in the terminals. but maybe i did it wrong. i think we agree that direct or push terminals will sound the same and are nearly the same in connection quality
BMW M340 xDrive
