i hope this isnt a vs thread. no names givn. the 2 10's are
Specifications Cutout Diameter 9.19 FS 32Hz Magnet Weight 90 oz Mounting Depth (in.) 5.25 Nominal Impedance S4.0 Ohm / D4.0 Ohm Power Handling RMS/Peak 350/1500 QTS 0.533 QES 0.583 QMS 6.302 Shipping Weight 13lbs Suspension Travel 50 mm VAS 15.72L Voice Coil Diameter 2.0"
the 1 15
Re: 4.0 Ohm
Fs: 32 Hz
Qms: 4.5
Qes: 0.63
Qts: 0.55
Vas: 74.5
Le: 4.36 mH
BL: 20.0
SPL: 88 dB
Sd: 856 cm^2
Mms: 307.2 g
Xmax: 20mm
Peak-to-peak: 62mm (2.45")
Power Handling: 600 watts RMS
Recommended enclosure info:
Sealed ~ 2.0 to 2.5 ft^3
Ported ~ 2.5 to 3.75 ft^3 @ 28 to 32 Hz
Cutout: 14.0"
OD: 15.5"
Mounting depth: 8"
Mounting flange to top of surround: 1.5"
Displacement: 0.19 ft^3
i got this from both websites. could anyone say for sure which would be louder? i have a cavalier and it would be a trunk car with the sub/subs and port facing the cabin. i have 1300rms available for power if that matters
2004 cavalier 2 door 5 speedalpine cda-103skar pax 6.5s
power acoustik D1-6000power acoustic 4-2600soundquest 1/0 throughoutDC XL M2 18 walledstock altbig 3 donestock battery under hood, 1400cca 400ah semi battery in the trunk
No way of knowing which will be louder but one 15 has more cone area than two 10s. Id go with one 15 but it's up to you. I you want two 10s go for it. it's all preference man.
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
thx for the reply. i have the 2 10's right now and was thinking of puttn a 15 in. im kinda loud now (low 40's) but i wanna be louder out of my trunk
Uness the 15" can be mounted vertically forget about it, in a trunk car 2 12"s is usually optimal, will overtake a 15" (most cases) and 2 10" as well.
depends on the box but i would go with the two 10's, thats just my opinion
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
Can you go two 12s?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
i dont really know. maybe if the box was built different. the way it is now, i can barely close my trunk. the box is about 3cf
well only use what your car can handle. the last thimng you wanna do is choke your subs with a box that is too small for them.
well i can have a custom box made but i dont feel like payn big bucks for that (ive never built a box for subs b4)
