Semper Posted June 12, 2012 Report Posted June 12, 2012 Okay, so I'm buying 2 SA-12s brand new. I'm running them off of a brz2100. I like the D2s, but I'm sure that they could take more than 1400 watts in total, so I also like the sound of D4s. It's just that I want the option to get a 3rd one. Because I could wire 3 D2s down to 1.3. What are my wiring options with 3 D4s? Any help is appreciated. Thanks. New Setup; H/U; Pioneer DEH-80prs. Wiring; 2 runs of 2/0 OFC & Big 3. Subs; 2 D1 DC Level 4s. Monoblock; DC 3.5k. 4 Channel; JBL GTO1004. Highs; Vifa NE25VTS-04. Mids; Aura NS6-255-8A. Alt; 160a. Batts; Optima, KHC1800.
Bump4life Posted June 12, 2012 Report Posted June 12, 2012 go D2. 1400 is plenty. you will notice a greater change when you add the 3rd woofer and wire to 1.3 than if you try to run 2100 to the 2 right now. you could also run at .5 ohm in the meantime if you have a wallet for something to go wrong. id stay at 2 ohm if it were me Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
TeamHT Posted June 12, 2012 Report Posted June 12, 2012 You...like....the sound.....of.....dual 4 ohm subs..... O_O Tell me...does this smell like chloroform to you?
Semper Posted June 12, 2012 Author Report Posted June 12, 2012 go D2. 1400 is plenty. you will notice a greater change when you add the 3rd woofer and wire to 1.3 than if you try to run 2100 to the 2 right now. you could also run at .5 ohm in the meantime if you have a wallet for something to go wrong. id stay at 2 ohm if it were me Yeah, I wouldn't risk it on my electrical. Alright, I guess I'll go with D2s. Thank you for the quick response. You...like....the sound.....of.....dual 4 ohm subs..... O_O Was a figure of speech. I meant I liked the sound of having the ability to wire 2 subs down to 1 ohm. New Setup; H/U; Pioneer DEH-80prs. Wiring; 2 runs of 2/0 OFC & Big 3. Subs; 2 D1 DC Level 4s. Monoblock; DC 3.5k. 4 Channel; JBL GTO1004. Highs; Vifa NE25VTS-04. Mids; Aura NS6-255-8A. Alt; 160a. Batts; Optima, KHC1800.
BobbyG2 Posted June 12, 2012 Report Posted June 12, 2012 Maybe he's had an amp that was 2 ohm stable, but wired his D2 to 1 ohm, and his D4 to 2, and didn't like the distortion the amp was making at 1 ohm? Although, it might not be noticeable to ear, but different impedance speakers do have slightly different T/S parameters. So, slightly different response. Example: Fi Q15 DUAL 1 | DUAL 2 Fs: 32.4 Hz | 32.1 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 8.52 | 8.61 Qes: .43 | .44 Qts: .41 | .42 Mms: 293g | 299g Cms: 0.82mm/N | 0.82mm/N Sd: 810cm^2 | 810cm^2 Vas: 75.6 l | 75.6 l Spl: 89.6dB 1W/1m | 89.4dB 1W/1m Bl: 13.9 N/A | 19.65 N/A Xmax: 28mm Rms: 1500W Sealed box: 2-2.6 cuft Ported box: 2.8-4 cuft @ 28-33Hz Sub OD: 15.625” Cut ID: 14.125” Mounting depth: 8.500” Displacement: 0.19cuft But again, it's really not enough of a difference to warrant a purchase do to different T/S parameters, it's mostly amp-dependant. *New vehicle and system coming soon.*
