DC Sound Lab
Amps...... DC pai 3000.1 (x2)
Subs....... (2) 15" fi btl's (fully loaded)
Was running amps strapped @ 2ohm and now I wanna run them seperately ( 1 to each woofer )
Can I still use only one knob safely if I use some sort of phone cable splitter??
TEAM DISTANT THUNDER
I dunno, but I would just get a PAC knob and split the RCA signal.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
This would be the correct way do do what you want. Just daisy chain the amps and you should be good to go.
Yup, run splitters off the RCA line from the PAC LC-1 to the amp, then make sure the amps are gain matched so one coil isn't getting more than the other.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
the lc1 has a in and an out, no splitting needed
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
RCA from sub output on head unit will go into the input on the LC1. RCA will now run from the LC1 output to the input RCAs on AMP 1, then run a set of RCAs from the output RCA on amp 1 to the input on AMP 2. Now gain match your amps and you are good to go.
Thanks guys.......dont matter now cuz both amps are fried :-( (not related to the remote gain knob either lol) not sure what did it yet but both the power supply on both amps are smoked unfortunately. But on the bright side I guess I can rebuild now.
  • Who's Online   0 Members, 0 Anonymous, 905 Guests (See full list)
