Hey guys. I got a 18" Fi BTL Fully Loaded with a Bxi2607d. Im using a capicitor, all 0 gauge wire. Im using a stock batt and alt.
Id like to make a list of the things i need to upgrade, but im not sure what else i need.
When i turn my volume up my amps cut out.
2008 Hummer H3
x2 Sundown Audio Nightshade V2 12s
x1 Sundown Audio 3000D
Ok awesome. And what all i would i need to hook up two batts in my car? Someone mentioned an isolator?
2008 Hummer H3
no isolater......waste of time and money. only works when your playing you system with the car off to save from dead battery. with a btl and kicker 2500, i would never play that voltage hungery amp with the car off anyways.
sencond batt is hooked up by running the + from the stock (front battery) to the + on the rear battery. then ground the - to the nearest, cleanest ground. then run a power wire fron the + of the rear battery to the + on the amp.
*gotFI? beat me to it*
DAMN YOU!!!11!!!!!11!!!
Edited by emat19876
  • Who's Online   0 Members, 0 Anonymous, 919 Guests (See full list)
