OrionStang Posted June 17, 2012 Report Posted June 17, 2012 Any fix for a scratchy 6.5"? Tried adjusting the x'over, turning down the gain. Nothing helps. Hertz 165Xl on the XL crossover. Is my mid about to go? SMD Super Seller My Feedback Thread
pimpnFosgates Posted June 17, 2012 Report Posted June 17, 2012 my beymas did that ust befor e one of em went also so id say yes but ther r a lot of ppl that know better than i do Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
Skullz Posted June 17, 2012 Report Posted June 17, 2012 1 channel, 2 channels? Possible it is the speaker but it is also possible it can be an amp issue or even a crossover. Best to try as many different things as you can to try and rule out as many or all as you can. Usually scratchy or bad sound is something inside an amp going but it could also be caused from something on a crossover going out too. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
OrionStang Posted June 17, 2012 Author Report Posted June 17, 2012 Well, I can rule out the amp because the tweeter on that channel is ok. Plus, the amp was already repaired. I did buy the crossovers used, so I will check them next. SMD Super Seller My Feedback Thread
Robert8252 Posted June 18, 2012 Report Posted June 18, 2012 Could be the crossover. I had something very similar with my Hi Engery 3" and ends up it was just the cars vibration around the door panel and such. If you hit that sweet resonance frequency of a panel it will drive you insane 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
