Voltage Drop BIG TIME :(
whats up guys, so im having some voltage drop in my electrical system.. just to give you guys some info i have about 340 Amp of current drawn from all my amps, i have a the big 3 all done with zero gauge wire stinger spp1200 front battery and then 1 run of zero gauge wire to a XS Power D3100 back battery and all amps are hook up to the back battery... i have a DC 270 Alt charging 15.1 Volts cold then 14.4V when hot. I know i should of got the 350 alt but i was a NOOB back then, well still are but learning more... when playing my system at full tilt my voltage drops to 12.3Volts on really bass heavy songs, or on normal songs at 13.8-13 sometimes 11.9 on High notes of bass (dont know why, since the subs dont move that much lol XD :noob: )... any help would be appreciated
Add another D3100 and some more wire. Done
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
check your grounds and maybe have another run of 1/0 to back batteries
right now i have the stock alt and i have no voltage drop. i have 3 runs of wire to my back batteries. you shouldnt have a problem with the 270a alt you have
edit: damn ninja
Edited by Miguels
Do another run from alt back and I would do a ground run at the very least from alt case to battery negative in rear.
Evo X build log
edit: damn ninja
now that you remind me about grounds i never sanded anything when doing the big 3 well the one to the motor should not that much of a problem since it was bare metal.. but the other one connected to he chassis i know i did have some paint... :fool:
ok... now thats a new one for me... getting the ground from the basket alt... but if it works it work... last question do you guys think i still need the other battery?? or should i just try with the wire and see what happens???
What is your voltage difference at the alt verses at the amp? If is over .5 volt then more wire is a must.
Evo X build log
I've noticed that the sub moves MORE in the upper range of my box...
E34 540iT/6
adding more runs will increase it a little, not much, but sounds like you need more reserve compacity, since you are drawing more power than your alt can make. Need more batteries to matain a higher voltage.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
  • Who's Online   0 Members, 0 Anonymous, 1078 Guests (See full list)
