High Voltage 2 Channel Amp
bre2ts
Are you talking about a "high Voltage" class A/B amp ?? I know mine will work great at 14.4 volts, but not 16.8 ...
If i'm not mistaken you can have the older PPI art series modded to run higher voltages but don't quote me on that as you'll want someone with more knowledge in amplifiers to chime in.
It seems like most amps capable of the higher voltages are the mono sub amps with very few multi channel amps capable of running in higher voltages.
EDIT:Does the car itself run on 16v/18v or do you have it on 12v and the rest of the system on the higher voltage? If your car is using a 12v system then just get any amp capable of the power you need and run it on your 12v system and the rest on the higher voltage.
Edited by Skullz
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
wonder is SD or stetsom or taramps could make one...
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
Something that can run on 16.8vdc daily
Why
They don't as of now st least not that I know of
Why
I have a 14v system
Anything decent with an unregulated power supply ought to be able to handle it, just be sure to go easy on the gain until you get a feel for it.
Any suggestions
you win some, you lose some
