Okay, so I want to install some copper bolts as terminals for my box.
How many do I need for 2 subs & how exactly do I use them?
Idk why, but my brain just cannot process how exactly I wire them.
Each sub to each bolt terminal, assuming I only need 2. But then how do I wire them to 1 2 or .5 ohms from there?
Pics would be helpful.
New Setup;
H/U; Pioneer DEH-80prs.
Wiring; 2 runs of 2/0 OFC & Big 3.
Subs; 2 D1 DC Level 4s.
Monoblock; DC 3.5k.
4 Channel; JBL GTO1004.
Highs; Vifa NE25VTS-04.
Mids; Aura NS6-255-8A.
Alt; 160a.
Batts; Optima, KHC1800.
What subs do you have 2ohmDVC or 4ohmDVC that decides your wiring options.
You put the two bolts in the box. You only need two unless you want to be able to switch coil config on the go but I'm guessing that over your head.
Than you wire the subs to the bolts on the inside just like you would to the speaker terminals on the amplifier. You will need crimp on ends that will tighten under the nut on the bolt and make a good connection. Than you run wire from your amp to the corresponding bolt.
I wil draw a rough diagram in pain lolz hold on.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
This is for dual 4 ohm subs to 1ohm final impedance. If they are 2ohm wiring like this would make a .5ohm load and instead you should wire to 2ohm.
What subs do you have?
Edited by Chris Hammer
Vehicles
2005 GMC Canyon
Sold to:
D2 SA-12s
New Setup;
Monoblock; DC 3.5k.
Alt; 160a.
I'll be soldering the wires to the terminal, instead of crimping. So it'll be a decent connection.
I plan on using Copper Bolts.
I just want to know how many bolts I would need to be able to change between .5 & 2 ohms. I'll be running 2 ohm for the time being, I just want the option to change, without having to remove the subs from the box.
New Setup;
Monoblock; DC 3.5k.
Alt; 160a.
Yea thats alot of wire and bolts just so you dont have to remove subs.
You could have two sets of bolts. One set for .5 ohms and have it wired that way....and another set wired to 2ohms. Thand make sure you cap off or cover the bolts not being used....than you could only have 4 bolts but 2 different coil options.
Vehicles
2005 GMC Canyon
Sold to:
Let me know how that finding copper bolts works out for ya cuz as far as I know they don't exist. Use alum or brass.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
  • Who's Online   0 Members, 0 Anonymous, 1371 Guests (See full list)
