DID THE BIG 3 UPGRADE!
i got my 0 awg wire in today nd terminals and i decided to do the install
i got done with 2/3 of the wires
+ to alt
- to engine ground
and after i tested it out with just the 2 wires i still get some dimming..i feel like i havent even made an improvement? :/
NOTHING DOWN HERE YET :(
OBSIDIAN FTW
When you say engine ground, do you mean the frame? or the block?
Do all 3 wires to complete the circuit.
Bat (+) to Alt (+)
Bat (-) to Frame Ground (-)
Frame Ground (-) to Block or Alt (-)
about how many amps is your system pulling?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
+ to alt
- to engine ground
Dimming is due to a sudden change in voltage. You could be dropping from 14.4 to 13.8 (which is completely safe) and the lights would dim. Do you have a volt meter?
Haha technically you didnt do the big three if you only did 2 of them but ya remember the currents drawn from the batt to the alt if you dont do the negative to the frame and depending on how strong a system or draw you might still dim.
  • Who's Online   0 Members, 0 Anonymous, 9719 Guests (See full list)
