Jextel Posted January 2, 2008 Report Share Posted January 2, 2008 I have a 97 maxima my loudest score was 145.6 in my kick...(AC180?) and that was on a stock electrical system and half the power..(and before my speakers were modded) So now this and next month my setup will be complete and hopefully getting it metered again.. My question is the damn rear deck! I have 2 large cutouts for 6.5 speakers i blew them from pressure of the air so i removed them and i want to build a new box with a port that sticks out and is flush with the rear deck...OR i can cut out more of the rear deck and slide the port through the rear deck then into the box...(it sounds awsome but what the hell can i use to cut through the deck? a dremel wont work, unless there is some kind of different bit..and i dont have a saw all) Another thing i was think was simply sliding round flared ports though deck then into the box..BUT i know i would need more than just 2 6" flared ports right? any other ideas of porting though the rear deck? ALSO i kinda tried sealing my trunk off with just 1 peice of wood and it wasnt loud at all just moved alot of air? PS loudest so far is having the port in the rear facing the passenger quarter panel Quote http://www.cardomain.com/ride/3042878TEAM DEADLY HERTZ "GET LOUD OR DIE TRYIN"only the loudest will survive. Link to comment Share on other sites More sharing options...
Charger Posted January 2, 2008 Report Share Posted January 2, 2008 PS loudest so far is having the port in the rear facing the passenger quarter panel That's what I was going to suggest. Try doing that with the woofer firing up, also try port to driver's side in that configuration, slide the box all the way back to the rear of the car. I wouldn't even bother venting your ports through the rear deck because it never works for SPL and it's alot more trouble than it's worth. Quote Previous 150+ daily rides: Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470 2 x Kicked Solo X 18s, Lexus LS400 4 x American Bass HD18 walled SMD - System of The Month August 2008 My Youtube Videos Link to comment Share on other sites More sharing options...
andym85 Posted January 2, 2008 Report Share Posted January 2, 2008 That's what I was going to suggest. Try doing that with the woofer firing up, also try port to driver's side in that configuration, slide the box all the way back to the rear of the car. I wouldn't even bother venting your ports through the rear deck because it never works for SPL and it's alot more trouble than it's worth. i disagree....porting thru the rear deck can increase spl...its all just very vehicle dpendant though. what kinda subs/amp are u running? 2 6" flared ports for a coulpe of 12s should be adequate port area. do you compete? b/c if you do then you might wanna read up on the rules b/c i know for MECA if you modify the rear deck whatsoever then you are automatically in the modified class....i sealed around my enclosure with expanding foam and it works fine. have u tried firing everything forward, if you seats fold down that is? Quote i likes me some audio stuff... Link to comment Share on other sites More sharing options...
Forevrbumpn Posted January 2, 2008 Report Share Posted January 2, 2008 was going to say the same, ported thru rear deck I just did a lexus last night with only 1-6" port firing thru the rear deck, not even sealed off, but aligned with the factory 8" sub hole Once its sealed off, it will sound better. But in comparison to the dual 12" ported box, all firing back, this was a HUGE improvement, played lower notes, louder, with better detail in the lower region, but it lacked the higher bass notes wich was kinda frusterating, well to the owner, not me. So yeah I would suggest bandpass thru the rear deck sealed off, or fold the seats down, woofers firing thru the seat, sealed off, with ports thru rear deck If doing bandpass, use as large of a port as possible Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy. Link to comment Share on other sites More sharing options...
Jextel Posted January 2, 2008 Author Report Share Posted January 2, 2008 That's what I was going to suggest. Try doing that with the woofer firing up, also try port to driver's side in that configuration, slide the box all the way back to the rear of the car. I wouldn't even bother venting your ports through the rear deck because it never works for SPL and it's alot more trouble than it's worth. hmmm my woofers fire up and port to the rear side right now.. I think deck porting will be my best bet... was going to say the same, ported thru rear deckI just did a lexus last night with only 1-6" port firing thru the rear deck, not even sealed off, but aligned with the factory 8" sub hole Once its sealed off, it will sound better. But in comparison to the dual 12" ported box, all firing back, this was a HUGE improvement, played lower notes, louder, with better detail in the lower region, but it lacked the higher bass notes wich was kinda frusterating, well to the owner, not me. So yeah I would suggest bandpass thru the rear deck sealed off, or fold the seats down, woofers firing thru the seat, sealed off, with ports thru rear deck If doing bandpass, use as large of a port as possible sounds good i might have to try a banpass anyone else recommend them? i disagree....porting thru the rear deck can increase spl...its all just very vehicle dpendant though.what kinda subs/amp are u running? 2 6" flared ports for a coulpe of 12s should be adequate port area. do you compete? b/c if you do then you might wanna read up on the rules b/c i know for MECA if you modify the rear deck whatsoever then you are automatically in the modified class....i sealed around my enclosure with expanding foam and it works fine. have u tried firing everything forward, if you seats fold down that is? hmm i dont do comps..maybe here and there just for fun(for now) im stricitly foucsing o being louder then everyone in my hood..and are you sure 2 6" ports will be enough? ill be pushing close to 3600wrms prolly more like 3000wrms... Quote http://www.cardomain.com/ride/3042878TEAM DEADLY HERTZ "GET LOUD OR DIE TRYIN"only the loudest will survive. Link to comment Share on other sites More sharing options...
Jextel Posted January 3, 2008 Author Report Share Posted January 3, 2008 I gotta find some way of cutting my rear deck out.. Quote http://www.cardomain.com/ride/3042878TEAM DEADLY HERTZ "GET LOUD OR DIE TRYIN"only the loudest will survive. Link to comment Share on other sites More sharing options...
LSN2meBoom916 Posted January 3, 2008 Report Share Posted January 3, 2008 http://www.stevemeadedesigns.com/board/ind...ic=5568&hl= Quote COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly. Link to comment Share on other sites More sharing options...
Jextel Posted January 3, 2008 Author Report Share Posted January 3, 2008 http://www.stevemeadedesigns.com/board/ind...ic=5568&hl= thanks i was looking for that build but did he already have that cut out in his rear deck? do yall think a cheap angle grinder from ebay will work? like $20 bucks cheap? Quote http://www.cardomain.com/ride/3042878TEAM DEADLY HERTZ "GET LOUD OR DIE TRYIN"only the loudest will survive. Link to comment Share on other sites More sharing options...
andym85 Posted January 3, 2008 Report Share Posted January 3, 2008 some hardware stores will let you rent out tools, even lowes or home depot might...see if you can rent out a saw Quote i likes me some audio stuff... Link to comment Share on other sites More sharing options...
LSN2meBoom916 Posted January 3, 2008 Report Share Posted January 3, 2008 (edited) thanks i was looking for that build but did he already have that cut out in his rear deck?do yall think a cheap angle grinder from ebay will work? like $20 bucks cheap? The opening I used as the "chimney" was already there-I didn't have to cut any metal in that case-just cut the rear deck material which was plastic...however a dremel with a cuttoff wheel, an angle grinder, a saws-all, or even a jigsaw with a high tooth count metal cutting blade would work fine just get some eye and ear protection while ur doin cuz it'll get real loud right by ur head in that tight of a space and the metal shards in the eyes=no fun. Worst case scenario-drill some pilot holes and bust out the keyhole/hacksaw. I'd say look at a rotozip that comes with the anglegrinder/cuttoff tool attachment included. I used a rotozip with the 1/8" spiral upcut bit-ok for plastic but not gonna do it for sheet metal. Edited January 3, 2008 by LSN2meBoom916 Quote COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly. Link to comment Share on other sites More sharing options...
