Zak Katzer Posted June 21, 2012 Report Posted June 21, 2012 2 skar VVX 12's on a 1500 watt amp. should i also keep stock alt/battery? 2012 Silverado ext cab Kenwood DDX470 XS D3400 (starter) XS D375 (under passenger seat) XS d3100 Mechman 240 Big three SMD VM-1 All SHCA wire 80 sq feet of Damplifier 6.5 Crescendo CZ's (front doors) (needed) 5..25 Crescendo CZ's (back door) (needed) Crescendo 125.4 (needed) Sundown Zv4 12 Skar 4500 (2ohm)
brandonlearL7 Posted June 21, 2012 Report Posted June 21, 2012 I have never done the big three and I use 4 gauge wire. Do you have a capacitor? Vehicle: 1999 Toyota 4Runner SR5Front Stage: Oxygen Audio O2 ComponentsRear Stage: Oxygen Audio O2 ComponentsSubs: 2 12" Obsidian V2 w/ Upgraded Black Aluminum SPL coilsBox: 5.94 Cubic Foot Tuned to 34 HZSub Amp: American Bass VFL150.1 Mids/Highs Amp: Rockford Fosgate 120.2 Head Unit: Kenwood KDC-X396Electrical: Single Run of American Bass 1/0, Single Run of American Bass 8 Gauge, Big 3 Upgrade Build Loghttp://www.stevemeadedesigns.com/board/topic/161818-1999-toyota-4runner-sr5/
HHR Ed Posted June 21, 2012 Report Posted June 21, 2012 1500w is right on the upper edge of a stock batt setup. Id suggest to just upgrade that battery and beef up your wiring. Wire gauge depends on how long you run it. To get a real 1500w, 4awg run from front to back is too small. 2awg will work, but 0awg will give you head room up to 2000w Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
ROLEXrifleman Posted June 21, 2012 Report Posted June 21, 2012 Just do 0. The price difference is cheap peace of mind if you ever upgarde anything else. Amd to much is better than not enough. What kind of amp draw is your amplifier pulling? That will be a greater factor on what upgrades, other that the 0 gauge, you will need. Rolex you sicken me. Just let me finish my pie ~ Juice
Rockbrook Posted June 21, 2012 Report Posted June 21, 2012 if you can afford to upgrade to bigger battery you should, if you can afford the 0 gauge do it, it'll be ran for when you decide to upgrade. I couldnt afford it, im running 4 gauge to stock battery, no light dimming issues really neither.
Gotta_LOVE_BASS Posted June 21, 2012 Report Posted June 21, 2012 4 or 0 would work iv been down the same path and brandonlearL7 GET RID OF THE CAP THEY ARE CRAP they r just another thing to drain power from the battery personally i would go with 0 gauge more room to grow but also agree with HHR Be Happy With What You Got
Zak Katzer Posted June 22, 2012 Author Report Posted June 22, 2012 thank you guys. appreciate all of the comments 2012 Silverado ext cab Kenwood DDX470 XS D3400 (starter) XS D375 (under passenger seat) XS d3100 Mechman 240 Big three SMD VM-1 All SHCA wire 80 sq feet of Damplifier 6.5 Crescendo CZ's (front doors) (needed) 5..25 Crescendo CZ's (back door) (needed) Crescendo 125.4 (needed) Sundown Zv4 12 Skar 4500 (2ohm)
MIKE-2U Posted July 14, 2012 Report Posted July 14, 2012 4 or 0 would work iv been down the same path and brandonlearL7 GET RID OF THE CAP THEY ARE CRAP they r just another thing to drain power from the battery personally i would go with 0 gauge more room to grow but also agree with HHR Funnt how you say this and you have/had a cap... 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
Tim Lam Posted July 14, 2012 Report Posted July 14, 2012 do the big three with 0 awg. keep your stock alt. upgrade the battery under the hood. (might i suggest a Kinetik HC1800?) and look at the inputs on the amp and just use the gauge of wire it says can fit (0awg is almost always preferred over 4awg)
siucsaluki11 Posted July 14, 2012 Report Posted July 14, 2012 Just run 0 ga and call it good. Im running 0ga to the trunk, HC1400 under the hood, no big 3 (yet) no 2nd batt, stock alt, BRZ1700 at 2 ohms and MRP-F300 at 4 ohms, voltage drops to 12.9 at full tilt while idling. Doing big 3 in a few weeks, hopefully it will stay a bit higher after that. woman..cant live with em...cant shoot em...guess were all fucked You might be a Redneck if you use your leftover gutters for a speaker box port... YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
