Wire AQ SDC 2.5 to 2 ohm on a mono amp??
Positive of coil 1 to positive of coil 2 to positive of amp output, negative of coil 1 to negative of coil 2 to negative of amp output.
Just hook both the positives to the positive on the amp, and both the negatives to the negative on the amp.
*New vehicle and system coming soon.*
there called direct leads.... do some research and you will find your answer in 2 seconds. But yes like stated above that sub is a dual 4 ohm woofer so wire in parallel red to red black to black then hook up booth reds to the positive and both blacks to negative. if you have to extend the wire you can use bolts or just twist the wire coming off of the woofer to more wire 12g-10g then run it through the box by drilling holes the size of the wire then using silicone or something to seal the wire to make sure it is air tight.
2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood
Mike Singer 250A SHCA and KnuKonceptz wire Big 4+
AQ / Dayton pro mids+monsoon tweets
My Build : http://www.stevemead...35#entry1989435
  • Who's Online   1 Member, 0 Anonymous, 1475 Guests (See full list)
