SA-8 V2 Box question.
i have an 04 f150 single cab....bow will be 36 length 14 tall 5 top 11 bottom with a 4in Precision aero fired to the passenger side..i have 2 sa8v.2..box should be at 36hz and i have a rf power 1000.bd. everyone that ive askewd said this should get pretty loud and deal with the lows pretty well
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
I can't check out the tune or box yet
But you'll wish you tunes I'd lower then 36
I can't quite remember the exact figures but you'll see a +5-7db gain over 35-42hz more then any other freq. And I has a sharp incline and decline to suit
All the box if done for others are 32-33flat, with no complaints
My own is 32.5hz and I love it
54 x10h x7/14d
Or
54 x14h x7/10d
That what have yes
54"L x Width 7 top x 10 bottom x 14Height
My box is W-56" H-14" TD-7" BD-10" as well. I'm tuned to 33 for a couple of 12s. After port displacement I'm at 2.00 cubic feet net but I plan to overpower the shit out of my subs so I'll be fine. Ray on this site(he's a big badass) had luck with a box that was running 2 8s in a regular cab of our same year. He had 2 4" aero ports firing into the passenger side B-pillar and I think it was hitting a 143 or so. Not bad numbers for 2 8s with nowhere for the air to go.
Done some figures
with a 14h 5td 11bd you'll have to put the subs 7.5" from the bottom to have enough clearance due to the motor size
With a single 4" aero on passengers side 17" (18 overall) you'll have unloading issues in a 36"width and clearance issues as well
You have 2 options
42x 14x 5/11 with a brace in the middle(same as sides) acting as a baffle between port and sub,
with both subs in driver side and port to passengers, divided by baffle
But only bring it up about 6" from bottom
Also he 4" aero is 7,25 in dia and just fits through the side of box at bottom and will just touch the bottom and 2 sides without cutting
Second option is
44x 14x 5/11
Double baffle front
Other then that its the same, still requires a side baffle 5-6" in front of port about 6" up
But the inside flare of port will need some trimming to acomadate the the double baffle front
Idd draw it for you but I'm not home,
If your willing to wait till same time tomorrow I'll be able to help out
Also my cal should put you at 1.4-1.5 net at 34.5-35hz
Amd the v2 are 0.1 and not 0.8cuft
Done some figures
You have 2 options
Second option is
44x 14x 5/11
Double baffle front
I have an idea of what you are talking about. If you can draw it out that would be great.
  • Who's Online   0 Members, 0 Anonymous, 861 Guests (See full list)
